Hello.
I'm building my first stereo amplifier, and I would like to share with you the ground/earth scheme I designed, for anyone to point errors in it, and hopefully make a better approach. It is based on local star ground scheme.
The amplifier is splitted in three boards:
- Power supply
- L-Channel
- R-Channel
The original schematic shows four filtering capacitors, all of them shared between channels.
I decided to split each of the pream and output stage capacitors (C1 and C3, respectively), in two (one for each channel), and place them in their respective boards, near the valves they supply filtered voltage to. This way, I can use a local star ground scheme, very easily, with short wires. The idea is to wire all vale circuitry ground (cathode resistor and bypass cap) to the ground terminal of their filter capacitor.
An image is worth a thousand words:
Then, there's a main star ground point, where all local star grounds go, and which connects to the chassis.
As far as I know:
- It is better to have a single chassis connection, at a single point.
- It is better to not do it at the first filter capacitor, but better to do at the input.
But this is a stereo, so there're two amplifiers, powered by the same transformer/supply. If connecting both inputs to the chassis, could this make a ground loop? I don't think so, but I'm unsure.
So just to be sure, I first decided that a single connection to earthed chassis could be done at the common filtering capacitor ground which is between phase splitter and output stage.
I read lots of info about the matter, but being my first unguided project, first stereo, and chassis building from scratch (thus facing quite several challenges), would like to avoid basic (and very time consuming) mistakes.
Thank you so much!
(of course, there's a chassis connection at the IEC socket, to the third prong wall plug)
- Power supply
- L-Channel
- R-Channel
As far as I know:
Thank you so much!
