Help with LM393 Voltage Comparator Required
micro571
I need to use this chip in a much larger circuit, but first I need to get a handle on it. I can't seem to get it to work properly.
When I turn the variable resistor, I either get 0.5V or 0V on the output pin. This isn't enough to light the LED. I was expecting 5V or 0V. Have I wired it up wrong? Are my resistor values off? Any suggestions would be greatly appreciated.
I copied the circuit diagram and changed it a bit to what I actually had.
Then I realized that the LED in the diagram had the negative side going into the output. I flipped around my LED and it worked. Oops.
When I was measuring voltage, I was measuring from output to ground, which would explain the low voltages.
My bad. :oops:
No, it has an open collector output, wich means it can only pull the output to ground, it can't put '+' on it. That's why you read those low voltages, It needs a pullup resistor on the output...
yup open collector. You really need a the LED-330 Ohm going from the 5V rail and the comparator output
