Hi I am making a sound sensitive disco light for my Year 11 Coursework project in Electronics.
We started working on the practical about 12 weeks ago and now there's only one week left
to finish it! After populating my PCB my teacher has been testing and fault finding my PCB for
over 3 weeks when I come in at dinner times 4 times a week. He is positive that there are no
faults left present in the PCB or in connections and is struggling to get my circuit working.
Here is my PCB mask:
Where there is a red line my teacher deliberately cut the track
Here is where the components go (ignore the white test only read the black text):
(The block in the top right is a 2 way slide switch)
At outputs to LEDs I have used fly wires to connect LEDs placed within the circuit to conserve
PCB space and allow the LEDs to be in the correct position.
Here is the circuit design (the microphone has been replaced with and MP3 jack, he says he has
done that before and it worked):
My teacher says that the first transistor in the circuit is working (not sure about the second
and not sure how a PNP transistor works) and the third transistor on the right isn't. On the
third transistor more than 0.3v is going into it and it is constantly on.
In the left half of the circuit there are signs of the signal from the MP3 jack as the dial wobbles
while the music is playing.
Also, here is my Project so far. The casing is shaped like a Hedgehog and the LEDs will be the
spikes![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Do you know why the circuit isn't working? Any help would be much appreciated.
-Josh
spikes
-Josh
