You have all three of your shunt references in parallel, so you will only see the lowest voltage in all positions of your switch. You need to give each of them their own dropping resistor. Or, tie the switch common to the resistor and op-amp pin, and the three switch points to the individual references.
But, you can probably use just one reference, and a three resistor divider to make the other two voltages. Just make sure that the values in the divider are significanly lower than the resistance values in the op-amp.
