Re: I give up
Easy to test - disconnect the bridge rectifier, put a new fuse in, plug it in. If the mains filter is S/C it will still blow the fuse.
Was Q801 faulty?, or did you change it as a matter of course?.
I can email you the PDF manual for the SD110, but it's 20MB!.
grandev said:Hi Nigel,the board is pc power 2700 and is from a Sd 1750 dvd player.I do have the 8 pin ic you mention,but again there isn't anything on gate of Q801..no d808 or d809??the ony diode without a # is across r815 and r813...and I changed that one...along with q801.....The t801 was smoking
at one time upon replacing fuse(before parts q801)so I was wondering if the t801 is testable(line filter)..thx
