There is always the old adage that says "The transistor failed to protect the fuse".
Correct. I've attached the relevant section of the schematic showing R3, C10 and flick timing revisions to date. As C10 has been increased in value I've also added R6 as a precaution to limit current into the inputs of gates U3c, U3d when C10 pulses high.It seems that the positive side should go towards +24V
Ah, but you're getting to be an expert by nowThis build is a little tougher than the last one.
Well if you haven't got 330k anything from 100k to 1meg would do.I'm pretty sure there are some 330K resistors bouncing around in my electronics junk drawer
If the blink is too brief it may not be visible. I've just knocked up a breadboard version of this part of the circuit. With my 'C10' = 0.47u and my 'trimpot' = 330k my LED blinks on for ~ 0.2 sec.I expected the other LED to just barely blink every minute or so, but nothing
DMMs in general are rubbish at measuring briefly pulsed DC. I tried that on the breadboard and got a fluctuating reading between 0 and ~ 0.4V.I set my DMM to 20VDC and held the probes to the LED wires and got nothing
During the run phase the LED should be on constantly for 30 secs (not blinking) then off for 5 secs. Or did you buy flashing LEDs?the LED that is blinking for the running pumps
Strange. Could be due to FET or Schottky diode leakage current, or spurious FET turn-ons due to noise (circuit presently unscreened).does not completely turn off between run times. It keeps a slight glow
Hooray!It is on for maybe 30 sec and off 5 sec
That indicates the 4020 isn't operating, and hence accounts for why there's no flick. Checking the Q4 output at the left side of C10 will confirm that. Check also that you're getting a clock signal (0/12V toggle every 2.6 secs) at the top end of R2 (= output of gate U2a). Then if that doesn't identify the problem it's a matter of double-checking all the pinouts and soldered connections of the 4020.I left the controller running and after nine hours, the same LED continues to operate. Adjusting the clock pot does not seem to matter.
Are you saying to take the completed circuit to a sink and scrub it?TIP:
It's also best to clean the flux off the joints as soon as possible. e.g. Wash the board with soap and water and a scrub brush. Acetone (nail polish remover) or Denatured alcohol can also be used as a solvent. Some fluxes are water soluable.
