I taped the magnet to the bottom of cardboard. Hoping it's a good enough pic. Thanks all.
As I said a few weeks ago it is a strange motor arrangement.
That's what was intendedit simply holds at constant current (IE basic current limiting)
Looks like the right driver. I cant see a two pole motor working efficiently.Have just come across this explanation of 2-phase BLDC motor operation :-
http://bldcfan.100webspace.net/
The circuit looks very similar to what I think must be in 'our' pump, even if the coil layout is different and the rotor/stator are 'inside out'.
Both body diodes are verified forward biased in the UP direction in both of our schematics.
so the polarities are backwards in our schematics and, I guess, the MOSFET appears to be N channel.
The PCB is definitely single sided. Some black Epoxy potting material is on about 1/3 of the back side.
The OEM switching regulator is a 3 Amp model.
The datasheet I looked at gives 4.2 - 6.9 amps at 25C or 3.5 to 7.5 over the temperature range. Do you have a different one?
It also has a thermal shut down, but that would be slow.
ronv said:Any chance the gate resistors are like the example Alec gave or are they definately like your picture?
You may be right. Easily done. However, I would have thought that even 3A would get the motor started, albeit somewhat sluggishly perhaps. Looking at the LM2576 datasheet again I see that the chip current limit varies from 6A to 4.5A as the (output transistor) junction temperature rises, so the OEM controller can't provide the ~11A t=0 current that the motor winding theoretically draws. Perhaps something like 5A might be a better limit to aim for?Alec, Might want to remove D5. Again, we can't be sure what the starting current needs to be. 3 amps may not be enough.
