Remember that the OEM controller has the LC ripple filter composed of the 68uH and 470 uF and this https://www.premmagnetics.com/Inductors company sells inductors to mortals.
Yes. And a lot to modify an OEM controller, or build any other driverA lot of headaches trying to build a homemade buck converter.
Does that matter? We're concerned especially with a locked rotor (i.e. a permanent start-up state), which is essentially a DC situation where current is determined mainly by the coil resistance.Spice doesn't model inductor saturation so it is easy for the current to be out of spec (for the inductor) during start up
That was a feature in one of my earlier designs (I've lost track), but Joe asked for an auto-reset solution.How about just latching the over current in the one you have so that it must be reset by hand on a failure?
alec said:Does that matter? We're concerned especially with a locked rotor (i.e. a permanent start-up state), which is essentially a DC situation where current is determined mainly by the coil resistance.
page 1 of Melexis UA79 datasheet said:Locked Rotor conditions are detected by the IC
when there is no motion for one second and will shut off the motor drive for five seconds. Then, the IC will turn on the drive current for one second. This sequence continues indefinitely until the locked rotor condition is fixed. This feature prevents overheating
1 second is an eternity for our electronics and I consider it a DC situation, compared to the 50kHz switching period, for design purposes.is Locked rotor a DC condition or is it 1 second on, 5 sec off?
A lot of headaches trying to build a homemade buck converter. One thing to worry about is the start up current. Spice doesn't model inductor saturation so it is easy for the current to be out of spec (for the inductor) during start up. It might be better to use a chip like the LT one you used before that takes care of all that "stuff'.
Below is what I was talking about. Note the inductor current as it charges the cap.
Yes, I remember it as a nice feature. If I have time today I'll go through the posts and see if I can generate a dream spec. With a reset to a blank sheet of paper it might not be that hard to meet.![]()
That sort of current is experienced by the inductor in the OEM controller, so presumably the inductor is rated accordingly or there'd be lots of irate customers![]()
The IC limits the current a plain pwm has no such safety.
Here comes the spec.
wavemaker said:On for 30 seconds, off for ~ 5 - 10 seconds. #178
tide controller said:#229 6 hours run time 6 hours off time. Flick or short pulse on to keep fish at bay.
OEM controller modification:
Advertized as unreliable.
Basic switch. No locked rotor protection
That little test you asked me to do, trashed the OEM controller.
The fuse didn't blow because my supply is current limited. The input is effectively shorted, so I SUSPECT the regulator IC. I did see things like the power LED was dim and then none of the Wave LEDS were on with a dim power LED.
The only real troubleshooting I did was to check for shorted capacitors and I checked the fuse in circuit.
What test was that Kiss?
I think eventually there will be 6 pumps, 4 for the wavemaker and 2 for the tide maker.
Joe can you fill in what the 5th and 6th pumps do?
Do you want 3 pumps to "flick" at once?
Still not sure if true or not. Overvoltage may have been the culprit.
Either way....... 10 amps thru the pump will fry it.
Should be. Just don't run or start the vehicle while your doing it. You may want to disconnect one cable too while your at it. But if your careful it shouldn't matter.I was just going to take a bucket of water to my truck and toss the pump in and not bother disconnecting the battery. That's OK, isn't it?
If you could give a quick drawing, a rough layout, or maybe some pictures of your unfinished tank and what you want to do, that might be nice for us to have. It's not required though and I don't actually *KNOW* how it can help. I just want to look like I'm doing something useful I guess.What I had in mind was......[What salty had in mind]
I don't think initial start up current is going to be too much of a problem with this design myself. Unless of course the rotor is locked and the coil fully saturates. Even a pump with shorted FET's is going to naturally oppose high currents for a time, do to inductance of the coils. But a simple over current shutdown would fix all of this easy. I think one of alec_t's current limited FET switch designs already did this well enough. something like 6 Amp instant shut down wasn't it?Current limited FET switch.
No current limit on initial start up.
Voltage not adjustable
Thermal problems on auto retry.
