noskcaj said:Is it possible to step up an output of 2.8mV to a input of 3V? Please help. 10q![]()
Yes it is, you need an amplifier with a gain of 1071.noskcaj said:Is it possible to build a circuit with an input of 2.8mV and an output of 3V?
noskcaj said:Hi all,
Thank for the infor.
I intend to use the PC parallel port to control 4 output devices. I wonder is it possible to be done. I had information is that I could use a 3V relay to control the devices. But the problem is that the Voltage that is coming out from the parrallel port is like ard 3mV but how am I able to drive a 3V relay to let the relay works.![]()
Hope I did made myself clear this time round.
i agree totallyNigel Goodwin said:The voltage out of the port is TTL levels, if it's only 3mV then the pin is set LOW and not HIGH.
