Russlk said:Communications is too broad a scope, what do you want to do? Transmitter/ receiver, DSP, phase lock loop, frequency synthesis, etc.?
thanx,i am suddenly confused as to the particular application of this freq synthesis. i am pretty new to this field. so.... i did check the listed urls, but the technical jargon was 2 much for me. so.... could i do something using the bluetooth as a sidethought (or that must be expensive!) plz suggest something.....Russlk said:If you do a Google search on "frequency synthesis block diagram" or "frequency synthesis theory", you will find some useful info. Also you should become familiar with these terms:
phase lock loop
VCO
frequency divider
mixer
prescaler
The CD4046 IC or 74HC4046 are useful in low frequency PLLs, application notes relating to these may be useful.
I did some searching and came up with these URLs:
https://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=frequency+synthesis+block+diagram
https://www.cs.washington.edu/homes/diorio/Talks/InvitedTalks/MTT97/
