zachtheterrible
Active Member
I did some more research and found that I can use at least 12VAC or 17VDC, is this true?
zachtheterrible said:I did some more research and found that I can use at least 12VAC or 17VDC, is this true?
Joel Rainville said:zachtheterrible said:I did some more research and found that I can use at least 12VAC or 17VDC, is this true?
Yes, it has a bridge rectifier, it's on the diagram, top left corner : **broken link removed**
Joel Rainville said:Are you using WinPic or WinPicProg? Those are two different programsAnd one sucks. :lol:
eblc1388 said:Joel Rainville said:Are you using WinPic or WinPicProg? Those are two different programsAnd one sucks. :lol:
Both are good. One even allow me to config/setup a new PIC not come with its default list and programmed it correctly.
eblc1388 said:If you cannot make the P16PRO40 work, chances are the ICD2 clone would be twice as difficult to get right.
Joel Rainville said:My point exactly. I fear that if the ICD2 doesn't work right from the start that Bryan will throw it all away and become a monk, or something...
The major problem I found with the circuit board is although I used my U-beaut power supply @ 17 volts and used a 317 calculator to determine the correct resistors to give me 13.1 volts, the voltage keeps on changing and won't stay above 13 volts. I even checked with the fluke the mlcr pin while programming and the high voltage varied from 12.93 to 11.54 volts when high.
Anyway enough ranting tomorrow is another day and I won't be that far away from sucess.
Cheers Bryan![]()
