So if I use a MCP6244 ( 1,8 ~ 5v device ) I'll be okay?? I haven't got the 15v device listed!!Hi Ian,
The current sense op amp (Pins 5, 6, 7) will not be a problem as both inputs will be very close to ground. The voltage sense op amp (Pins 1, 2, 3) will have the output voltage scaled down by R9 and R10 1.8K/(1.8K + 10K) = 1.8/11.8 = 0.1525. So when thye output is at 20 volts the input to pin 3 of the op amp will be 20 * 0.1525 = 3.05 volts.
Les.
Both have a specific +0.3vdd maximum on all out / inputs...
Nice little circuit.... I'm converting the code to C and using a small LCD for the readout...
I have a TIP107 ( Darlington ) and all the other components.... I've always wanted to build one of these!!!!
