Hi Guys need help with a charger circuit please
Yes. Use the Delete or F6 (copy) key or click the Move icon, as appropriate, then left-click and drag a marquee around what you want to delete/copy/move. Left-click to drop (paste) the marquee contents. You can paste into the current sheet or into a new sheet.
Bum and blast, no wonder things didn't make a lot of sense to me with the bottom circuit, I discovered today that I had C 11 at .22, I have been pulling my hair out trying to figure out why I am apparently getting no gain out of the amp, of course it dawned on me that would be .22 farad and needed to be .22u :arghh:
Why is there no caps in the selection below .5?
I've been caught out before by not specifying units. Also, I once put '0.1F', intending 0.1Farads. Spice interprets the F as 'femto' !!
A quirk. Once you have selected a specific brand/chemistry/voltage rating of cap, subsequent changes to the selection only offer a limited choice. My workaround is to delete the cap then insert a generic cap again then select (from a full range) brand etc if necessary. For many sims the generic cap is ok.
What's "femto" ?
Is there a list or anything anywhere which shows what all the components starting with LT are?
Its fast!
femtosecond - one quadrillionth (10^-15) of a second; one thousandth of a picosecond
E
There is nothing to indicate monitoring of the battery temperature, or reducing the charge current as the battery capacity or temperature increases.
