Hero999 said:Yes, that's true the manufacturers can insure that all of the diodes were cut from exactly the same peice of silicone. You can't do this so you'll have to buy a bag of 100 or more to pick out a close enough match for four diodes.
awright said:I think your money and effort are better invested in obtaining diodes rated for the application. (Now I fully expect Nigel to come up with a source for 50 cent resistors with a value of .001 ohms. Such a resistor would give a 0.05 volt drop for current equalization and dissipate 2.5 watts at 50 amps. That would change the cost/convenience equation.)
Hero999 said:But what value resistors?
I'd recommend a value that would give double the range of volt drops in the diodes. Suppose you need 1A and one diode is 0.65W, and the other is 0.7V then use a restor that will give a 100mV drop which 0.1 ohms. Am I right?
