Here is a constant-current switch-mode regulator derived from Hero's reference. I show how it handles start-up, turn-off, and variation of input voltage from 12 to 15V. I set the output current to 1.7A. The current is set by the 0.33Ω shunt resistor and the Vbe of the 2N3904.
The inductor is 10mH, and must handle 2A without saturation. The dissipation in the FET is miniscule, in fact the only significant dissipation occurs in the shunt resistor (~1W) and the LEDs (~4.5W each).
Now all we need is someone to build it
I see one potential problem with a switcher vs the linear regulator I presented earlier. It will be a ***** to keep it out of any audio in your car. It switches at an audible rate, and varies frequency as the input voltage changes. I tried one like this (for incandescent lamp dimming) in an airplane once, and could not get it out of the headphone audio. I gave up and went to a linear transistorized dimmer instead. There is about 2000 square feet of aluminum to heatsink transistors to in an airplane.
