homemade computer
No it used to run with a 450 watt psu. I don't think that is is a psu overload because I can turn it on for over 2 seconds.
Yours Truly Sciencenerd
First of all a CPU isn't going to overheat in just a few to even several seconds and shut down. Above you claim it worked when running from a 450W PSU. I'm assuming all the PC components you asssembled together worked fine with the 450W supply. You then swapped the 450W for a 300W supply? If so, there's your clue right there. Put the 450W supply back in. One of the supply rails may have a higher current rating that's allowing the PC to remain running fine.
In my experience this has been caused by either a short (a loose screw on the motherboard somewhere) or a bad power supply.
You can pull the power supply, short the green and a black wire (this turns it on and must be done) and test (with a volt-meter) that all the 5V connections are providing about 5V, the 12V connections about 12v, the 3.3V about 3.3V, etc. And you can test each ground as well.
Also, applying thermal compound on the CPU is something you should get comfortable with. I think it is a good idea to every year or so completely tear down the computer, clean out all dust, remove the CPU heat sink, clean off the thermal compound, and apply fresh compound.
Yes it CAN be a power supply problem. My last power supply was going bad and it could run for days some times before the computer would "randomly" shut down. Other times, it would only be a few seconds after turning it on and it would shut down.
Yes the CPU CAN over-heat after only a few seconds. Its a built in safety device. CPUs heat up very quickly when their cooling system is not working properly.
-Chris P
