My Pspice manual is 15 years old, so the interface may be different, but somehow you have to get the SPICE command into the SPICE file. The command is: .AC XXX p f1 f2
Where XXX is either:
LIN for linear frequency scale
OCT for logrithmic scale by octave
DEC for logrithmic scale by decade
p is the number of data points per OCT or DEC
f1 is the start frequency
f2 is the end frequency
Note the period in front of AC, which denotes a command
The interface may be presented as a Fourier converter, but you will have to fill in the parameters.
With newer pspice versions the procedure is exactly the same. You chose AC sweep, then AC sweep type (linear, logarithmic) and then enter start and end frequency and points per decade.
yes, and multisim (electronics workbench) also has the AC sweep function. go to Simulate -> Analyses -> AC analysis then define the start and stop frequencies and the type of sweep (logarithmic or linear etc). also define the variables (nodes) which you want to evaluate
