Did I say I've only had one power strip apart? I don't recall saying that. I've had a number of them apart. But if you don't believe me, go ahead an drill through from the top. I'd suggest plugging the drill into the power strip when you do so so you'll know instantly if you've screwed up.
He he, dont get your panties in a bunch now over this
You are saying that you have a number of them apart, and that's very good, good to hear.
However, your consensus is still based on a sample set that is too small. How do i know this? Because you are implying, rudely i might add, that every power strip will be damaged to the point where it wont be usable anymore, and that it would be stupid to do such a thing, all even after i ALREADY SAID that i have one right here in front of me that has CLEAR path from the back to the front without hitting ANYTHING whatsoever.
So your sample set is missing as a minimum, ONE power strip, and that is the one right here before me.
I was going to take a pic, but it would be hard to see. Maybe a drawing would be better that shows the two chambers.
I have taken a few different types apart too, and NONE of them have THREE wires running down the middle.
Maybe we have different power strips? There are a lot of different makes and models.
I did have one a long time ago that was WIRED similar to how you say, but i am not sure what happened to it over the years. It was small but was made of metal not plastic. It had a rocker switch and fuse, not a breaker like the other ones i have.
Because of your reply though i will be extra careful and as i said, once i get it apart i will know right away if this can be done with that particular power strip or not. The one i have right in front of me now though is clear that it would work just fine. Too bad that's not the one i want to use though
I'll take a pic in a minute or two...
Ok, check out the back of that one.
With this one you could be screws front to back and they would not hit anything because those holes are in separate chambers from the electrical part.
