When the cap comes into play, we might design this stage such that the cap reactance looks somewhat like a resistor at a particular max design target frequency. If we wanted a gain of 10 at the max frequency, then we would have made the cap value appropriate to make the total resistance look like 1000 ohms. So now we have two more gains to look at:
1. 10000/1000 (my approximation)
2. 10000/1010 (your approximation)
So my approximation yields a gain of 10 and yours a gain of 9.9, not a heck of a lot of difference there.
You're approximation is better than my "very rough" approximation. Your's just requires more basic knowledge of the workings of the transistor to be able to apply than mine does.
For Winterstone's benefit and hopefully for the OP's benefit, i'll modify my formula
So ok there Winterstone, does that make you feel more comfortable now?
Ratchit:
I take it you agree with that post's formulation which i will repeat here in the hopes it may help:
Ic=Is*(e^(Vbe/VT)-1) Given a 2N2222A transistor, a 10v DC supply source, a 1k collector resistor, and a 1 ohm external emitter resistor, and a base emitter voltage of 0.65 volts, what is the collector current? You may assume that VT=0.0257 volts due to the temperature. Since we want to use that formula we dont allow a circuit simulation for now.
So if you want to agree with him then do you agree with that formula, and what is the collector current in my previous post?
MrAl,
Certainly I agree with him on Shockley's formula. I certainly do not want to disagree with Shockley, do I? If you want me to calculate Ic, then you have to supply me with an Is value.
Ratch
Perhaps so, but that's not the question that i asked. This has been your third reply to the post with the question and still no answer to what Ic is.
You have the formula now so do you want to calculate Ic or not?
Question:
Given a 2N2222A transistor, a 10v DC supply source, a 1k collector resistor, and a 0 ohm external emitter resistor, and a base emitter voltage of 0.65 volts, what is the collector current? You may assume that VT=0.0257 volts due to the temperature.
[note i replaced the 1 ohm resistor with 0 ohms to make this simpler but it would come out very close to the same result with the 1 ohm resistor]
So we already have the operating point picked out for us, as well as the collector resistor and there is no external emitter resistor.
Care to shoot for a fifth post with no direct answer![]()
Yes but it shows up in the same thread (post 2) by the same guy and that's where the whole voltage control idea stems from.
MrAl,
I believe I already answered the question, with the assumptions I made, and assuming that the 10 volts is applied only to the collector. If no voltage is applied to the base, then no current will exist.
Ratch
Hello again MrAl and Ratch,
because we have met already in this thread, I take the opportunity to jump into this new discussion in order to contribute my opinion.
I know, my previous answer in post#34 regarding the resulting Ic value was not (could not be) really satisfying.
However, that`s the only answer that can be given if Is is unknown.
But we have, of course, a similar problem using the relation Ic=B*Ib.
In this case - assuming for example Ib=1uA and B unknown - we have Ic=B*1E-6 A .
However, such an exercise has nothing to do with the physical principle of Ic control. And this was - as far as I have understood - the start of the discussion, was it not? (See the quoted sequence above).
Here we have clearly to distinguish between „to control“ and „to determine“ the Ic value, respectively. And your question to Ratch concerns Ic determination!
According to Shockley`s equation, the amount of collector current is determined by three quantities (Vt, Vbe, Is), however, there is only one external parameter that can control (modify, vary) the current Ic - and that is undoubtly the base-emitter voltage Vbe.
To me, it seems to be logical that a particular value for Ic can be calculated only if all parameters that determine this value are known. And this applies to B as well as to Is.
I am aware that the uncertainty range for Is is much larger than for B - however, this cannot be a criterion for the discussion voltage vs. current control (physically!).
(By the way, the influence of the Is uncertainty range can be reduced drastically using Re feedback).
More than that, we shouldn`t confuse the physical principle of Ic control with the practical implementation. Of course, there are solutions for dc biasing a BJT with a current Ib.
However, a closer look reveals that we have, of course, not a „current source“. Instead, it is a simple voltage divider between the static DC base-emitter resistance Rbe of the BJT and a large external resistor Rb - driven with a voltage.
And one shouldn`t forget: For calculating Rb (based on a given Ib) we need a value vor Vbe ! I repeat: Even the so-called „current biasing“ needs an assumption for Vbe.
Regards
W.
Ok, so this is your fifth post after the question and you still havent answered it. You're really being confusing now because you said if no voltage is applied to the base then no current will exist, yet i CLEARLY gave you a base emitter voltage of 0.65 volts.
I asked him a simple question, to calculate Ic with known values with a known transistor using the formula quoted in the thread he pointed to. He agreed that the formula was correct, but after 5 replies he still hasnet calculated the value of Ic for that circuit and operating point.
But the main point was that if the voltage control method was so much better, then we should have easily obtained a result by now.
'Is' is not given yet, but the transistor part number was given, 2N2222A. I think we can find a range of Beta on the data sheet, but we cant find Is can we? Perhaps you can find it, but you seem to be at a loss for this parameter too and this is just one little circuit with one little resistor in the collector![]()
And remember we are looking for a particular current here, not an algebraic expression that leads to the current, so it should be like 1ma, 10ma, 100ma, 1000ma, etc.
