how to code to connect Relay RY5W-k using Pic18f4520?
Hi guys, i'm having some trouble in coding the relay. Anyone have links of tutorial or guides?
Which language are you using for programming the PIC.?
Did you sort out on how to connect the relay and transistor to the PIC.??
E
I'm using C# language. yeah I tried to connect relay with diode,transistor,LED and resistor to PIC. whenever i send 1 from the port to the relay. LED will light up. Now i need to develop something like, whenever i press a push button, relay will stop the batteries from charging and ADC will then measure the voltage of the each batteries.
