How to connect 2 output ports to an input port in Orcad?
EngIntoHW
There are two sources that control the RSTn pin of the 8051 Uc - a button and an EV board which interfaces the PCB through holes in the PCB.
Each port is in a different hierarchical block.
Orcad issues an error that there are two output ports connected to each other.
How to do it correctly then?
Thanks.
Why not just change all the ports to being bi-directional?
You could make them bi-directional as Sceadwian already suggested, or you might re-lable the outputs RST_N1 & RST_N2 and change the existing input port to RST_N1 and add another input port labled RST_N2 and jumper the two input ports together in Capture, or you could do the hard thing and get into the netlist and change the netnames if the version you are running will allow.
