EMMANUEL TOM
Please am building a inverter project with the chip SG3524, I want to ask if there is away to convert it output wave to sine wave
Hi ET,Please am building a inverter project with the chip SG3524, I want to ask if there is away to convert it output wave to sine wave
Hi AG,An inverter drains a battery so you want the inverter to very efficient and not waste battery power by making heat.
1) If you filter the output of a squarewave inverter to make a low frequency sinewave then the filter parts will be huge and expensive and they will waste a lot of battery power making heat. Also the output voltage will be low.
2) If you filter the low frequency squarewave output of an SG3524 IC to make a low frequency sinewave then you can use a powerful linear audio amplifier to make a powerful sinewave and waste a lot of battery power making heat.
3) Use #2 above but use an efficient class-D audio amplifier.
4) Use a Pulse-Width-Modulation system (PWM) using a high frequency squarewave that works like a class-D amplifier and its output is a low frequency sinewave with hardly any wasted power making heat..
Ah, yes I understand that well, but can you use a small high frequency transformer by chopping up the half sine wave, say with 100KHz. For the duration of the half sine wave the flux will all be in the same direction so won't you need a large cross section core to stop the transformer from saturating?A low frequency transformer will not pass the kHz PWM frequencies. A low frequency transformer is large, heavy and expensive (and it works poorly). A high frequency transformer is small, light weight and cheap (and it works well).
Hi ET,
The SG3524 is a driver chip. Normally for an inverter you would also need two power switching devices (MOSFET, BJT ot IGBT) and an output transformer.
There are basically two types of sine wave inverters: pure sine wave and modified sine wave.
We need to know a lot more information than you have provided:
(1) waveform, pure or modified
(2) input source (voltage and current)
(3) output required: voltage and current
(4) frequency required
Failing that if you just want a direct answer to your question, no you cannot convert the output of an SG3524 to sine wave.
Hi spec thanks,
(1) any of the two but since the pure sine wave will not be easier, I prefer the modify sine wave
(2) yeah
(3)yeah
But to demodulate the PWM signal and generate the low frequency modulation (50 or 60Hz) for he inverter output you will need a large mains type transformer that passes the low frequency and rolls off he high frequency.A low frequency transformer will not pass the kHz PWM frequencies. A low frequency transformer is large, heavy and expensive (and it works poorly). A high frequency transformer is small, light weight and cheap (and it works well).
Yes, agree that the amplifier dissipation will be very low but, that does not address the question about the flux in the primary of the output transformer. I simply do not know the answer.Class-D audio amplifiers use PWM and do not get hot, operate the switching at hundreds of kHz, produce output frequencies down to 10Hz and do not have an output transformer. Some do not even have a lowpass filter at the output but when they do it is small and cheap. An inverter can be the same.
Only if you don't need to increase the output voltage from the PWM signal.Class-D audio amplifiers use PWM and do not get hot, operate the switching at hundreds of kHz, produce output frequencies down to 10Hz and do not have an output transformer. Some do not even have a lowpass filter at the output but when they do it is small and cheap. An inverter can be the same.
Hi spec,
Some more modern inverters use a high frequency inverter to generate about +/- 300 volts DC and just chop that into a rectangular wave form. I do not see why the swiching of the high voltage DC could not be pulse width modulated to produce something close to a sine wave.
Les.
Hi spec,
Les.
(2) 12V 65AHi ET,
Got the sine wave bit but you have not answered questions (2), (3), and (4).
spec
