Hey - I have a pickit2 and a PIC16F690. I've been trying to figure out [by reading the datasheet] what the default pin configuration.
I was taking the standard blink program which was using I believe [I'm at work don't have everything] PORTB to toggle the led on/off.
I figured OK a good starting point would be to use PORTC and see if I could get the helloworld working. Nada. I finally found a counter example where they said some pins have dual use so make sure you clear/set the proper setting when you start. Makes sense. I have been reading through the data sheet and either don't know what to look for or just cannot find the default pin settings?
I could resort to experimentally turning on/off ADC, Comparators or whatever else might be doubled down but it would seem that I *should* be able to read this someplace?
