vik1501 said:Kinjalgp
How do I download schematic ? I am using a transformer typically found in epabx system. I am using 0.1uF cap in series with coil winding as follows. I have tried to put this in following format. I hope u understand !!
Can u suggest some tools ?
(GND)
------[100k]----[100k]----(VCC)
|_________________+ of LM324<3>
tone signal <1> tip
fr mt8888 ------coil xf --[0.1uF]---
----------->[ 0.1uF ]----> [ 1k ] __- of LM324<2> | () ()
----[var 47K]---------- |GND ------ring
( Amplifier using LM324 )
0.1uf is used to isolate dc level on either side. Non inverting i/p is provided with voltage divider to set dc voltage at 2.5V.
Gain is adjustable
I did some jugglery as above :? and tried to see the numbers on caller id device. The nos are displayed incorrectly. Nos 8,9,1,5 are not seen at all when i tried to send tone sequence 012345678901... on line
Regards & thanks
vik1501 said:Oh ! I did it !!
The problem was one port pin of microcontroller was bad. It was remaining at VCC level all the time. Hence wrong o/p from dtmf generator. :shock:
Thanks to all those who kept scratching their heads....Now no need to do that friends !!!
19fa952 said:hi![]()
i have same problem please send for me schematic if it is possible
thank
phalanx said:19fa952 said:hi![]()
thank
Is that an offer or a request? :lol:
