How to set internal oscillator frequency in XC8 C code?
Flyback
Hello,
I am using microchip's free XC8 compiler in MPLAB.X to program in C for the PIC18F65K22.
We wish to use the internal oscillator, set to 1MHz, but cannot do this...."OSCCON = 0x36" does not work.
Do you know how to set the frequency of the internal oscillator?
Also, do you know how to use the delay command "__delay_ms(100)", because this also doesn't work in my code.
I looked at the compiler manual and the micro datasheet but they don't appear to tell these things.
Here is my code so far...
// * File:   3 CHANNEL UV LED CONTROL SOFTWARE
//THIS SOFTWARE IS FOR THE "3 Channel UV LED Driver _D" PCB, and the
//"3 Channel UV LED Driver _E" PCB
//Reset and clear are not implemented, the reasons for them is unknown.
//'Updated_550587' PCB
//;WE ARE TRUNCATING THE ADC REGISTER SO JUST USE UPPER 8 BITS
//This code assumes LED MCPCB thermistors with B=3970 and 10K @ 25degC
//Makes sure the current level is never changed more than about 4 times
//per second.
//;DEFINE INPUTS FROM DIPSWITCH
//;Note that the new board has pullups on the dipswitch,
//;whereas 550587 PCB had pull downs, thus logic is reversed.
//; XXX DIPSWITCH POLARITY:- XXX
//;DIP 1...ON = EXTERNAL CONNECTOR CONTROL
//;DIP 2...ON = LOGIC HIGH (note 'ON' gives a low input)
//;DIP 3...ON = LOGIC HIGH
//;DIP 4...OFF = 10V is for max current
//;DIP 5...OFF = 80degC, ON = 90degC
//;DIP 6... UNUSED
//;DIP 7... UNUSED
//;DIP 8...ON = NO FAN FITTED, OFF = FAN FITTED
//; XXX  EXTERNAL CONTROL CONNECTOR POLARITY:- XXX
//;CLEAR = ACTIVE HIGH
//;RESET = ACTIVE HIGH
//;CH1...HIGH = ON, LOW = OFF
//;CH2...HIGH = ON, LOW = OFF
//;CH3...HIGH = ON, LOW = OFF
//;List of input ports:
//; ************** DIPSWITCH INPUTS:
//;DIP1 = RB0
//;DIP2 = RB1
//;DIP3 = RB2
//;DIP4 = RB3
//;DIP5 = RB4
//;DIP6 = RB5
//;DIP7 = RC5
//;DIP8 = RE6
//;************* External connector INPUTS:
//;clear =       RC1    clears when high
//;ch3 on/off =  RC7    channel on when high
//;RESET =       RD5    reset when high
//;CH1 on/off =  RD6    channel on when high
//;ch2 on/off =  RD7    channel on when high
//;Other inputs (DIGITAL I/O
//;Fan tacho = RG2
//;mclr =      RG5
//;Inputs that are ADC inputs:
//;RA2 = AN2
//;RA3 = AN3
//;RA5 = AN4 ADCON0=0x10
//;RF1 = AN6 ADCON0=0x18
//;RF2 = AN7
//;RF3 = AN8
//;RF4 = AN9
//;RF5 = AN10 ADCON0=0x28
//;RF6 = AN11 ADCON0=0x2C
//;RF7 = AN5  ADCON0=0x1C
//;**********ADC INPUTS:
//;AN0 = NC
//;AN1 = NC
//;AN2 = VREF- (0V)
//;AN3 = VREF+ (3V)
//;AN4 = Therm ch1
//;AN5 = I_CH1
//;AN6 = 0-10V control input
//;AN7 = PCB thermistor
//;AN8 = I_ch2
//;AN9 = I_ch3
//;AN10 = Therm-ch2
//;AN11 = Therm-ch3
//;OOOOOOOOOOO LIST OF OUTPUTS:
//;Trip =          RA4
//;Indicator LED = RC2
//;MCP4013_CS =    RC3
//;MCP4013_UD =    RC4
//;Shutdown-Ch2 =  RE0
//;Shutdown-Ch1 =  RE1
//;Fancon PWM =    RE4
//;Shutdown-Ch3 =  RG0
//;NCNCNCNCNCNCNCNCNC LIST OF NON CONNECTED PINS:
//;RA0
//;RA1
//;RA6
//;RA7
//;    RB6  = PGC
//;    RB7  = PGD
//;RC0
//;RC6
//;    RD0
//;    RD1
//;    RD2
//;    RD3
//;    RD4
//;RE2
//;RE3
//;RE5
//;RE7
//;    RG1
//;    RG3
//;    RG4/*
#include <xc.h>
// CONFIG1L
#pragma config RETEN = OFF      // VREG Sleep Enable bit (Disabled - Controlled by SRETEN bit)
#pragma config INTOSCSEL = HIGH // LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
#pragma config SOSCSEL = HIGH   // SOSC Power Selection and mode Configuration bits (High Power SOSC circuit selected)
#pragma config XINST = ON       // Extended Instruction Set (Enabled)
// CONFIG1H
#pragma config FOSC = INTIO2    // Oscillator (Internal RC oscillator)
#pragma config PLLCFG = OFF     // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF       // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = OFF     // Power Up Timer (Disabled)
#pragma config BOREN = NOSLP    // Brown Out Detect (Enabled while active, disabled in SLEEP, SBOREN disabled)
#pragma config BORV = 0         // Brown-out Reset Voltage bits (3.0V)
#pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
// CONFIG2H
#pragma config WDTEN = OFF      // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1048576  // Watchdog Postscaler (1:1048576)
// CONFIG3L
#pragma config RTCOSC = INTOSCREF// RTCC Clock Select (RTCC uses INTRC)
// CONFIG3H
#pragma config CCP2MX = PORTC   // CCP2 Mux (RC1)
#pragma config MSSPMSK = MSK7   // MSSP address masking (7 Bit address masking mode)
#pragma config MCLRE = OFF      // Master Clear Enable (MCLR Disabled, RG5 Enabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Overflow Reset (Enabled)
#pragma config BBSIZ = BB2K     // Boot Block Size (2K word Boot Block size)
// CONFIG5L
#pragma config CP0 = OFF        // Code Protect 00800-01FFF (Disabled)
#pragma config CP1 = OFF        // Code Protect 02000-03FFF (Disabled)
#pragma config CP2 = OFF        // Code Protect 04000-05FFF (Disabled)
#pragma config CP3 = OFF        // Code Protect 06000-07FFF (Disabled)
// CONFIG5H
#pragma config CPB = OFF        // Code Protect Boot (Disabled)
#pragma config CPD = OFF        // Data EE Read Protect (Disabled)
// CONFIG6L
#pragma config WRT0 = OFF       // Table Write Protect 00800-017FF (Disabled)
#pragma config WRT1 = OFF       // Table Write Protect 01800-03FFF (Disabled)
#pragma config WRT2 = OFF       // Table Write Protect 04000-05FFF (Disabled)
#pragma config WRT3 = OFF       // Table Write Protect 06000-07FFF (Disabled)
// CONFIG6H
#pragma config WRTC = OFF       // Config. Write Protect (Disabled)
#pragma config WRTB = OFF       // Table Write Protect Boot (Disabled)
#pragma config WRTD = OFF       // Data EE Write Protect (Disabled)
// CONFIG7L
#pragma config EBRT0 = OFF      // Table Read Protect 00800-017FF (Disabled)
#pragma config EBRT1 = OFF      // Table Read Protect 01800-03FFF (Disabled)
#pragma config EBRT2 = OFF      // Table Read Protect 04000-05FFF (Disabled)
#pragma config EBRT3 = OFF      // Table Read Protect 06000-07FFF (Disabled)
// CONFIG7H
#pragma config EBRTB = OFF      // Table Read Protect Boot (Disabled)
#include <stdint.h>
void    set_ana_dig_ports(void);
void    disable_interrupts(void);
void    disable_pullups(void);
void    disable_opendrain(void);
void    disable_comparators(void);
void    setup_adc(void);
void    setup_ports(void);
void    NC_pins_low(void);  //make all NC pins low.
void    read_dips(void);
void    set_initials_int(void);
void    set_initials_ext(void);
void    read_extreg5(void);
void    pre_internal(void);
void    pre_external(void);
void    set_initials_int(void); //dip/curr
void    set_initials_ext(void); //dip/curr
void    externalmode(void);
void    internalmode(void);
void    set_current_int(void);
void    set_current_ext_AH(void);
void    set_current_ext_AL(void);
void    setcurrent_ext(void);
void    top_mcp4013(void);
void    int_change(void);
void    ext_change(void);
void    change_current_int(void);
void    change_current_ext(void);
void    read_temps(void);
void    read_analog(void);
//CONFIGS
/*DEFINE OUTPUTS*/
#define ch1out      LATEbits.LATE1
#define ch2out      LATEbits.LATE0
#define ch3out      LATGbits.LATG0
#define ind_ledout  LATCbits.LATC2
#define fanconout   LATEbits.LATE4
#define tripout     LATAbits.LATA4
#define mcp4013_csout  LATCbits.LATC3
#define mcp4013_udout  LATCbits.LATC4
//DIPSWITCH INPUTS
#define dip1pin     PORTBbits.RB0
#define dip2pin     PORTBbits.RB1
#define dip3pin     PORTBbits.RB2
#define dip4pin     PORTBbits.RB3
#define dip5pin     PORTBbits.RB4
#define dip6pin     PORTBbits.RB5
#define dip7pin     PORTCbits.RC5
#define dip8pin     PORTEbits.RE6
//DEFINE INPUTS FROM EXT. CONNECTOR
#define resetext       PORTDbits.RD5
#define ch1ext    PORTDbits.RD6
#define ch2ext    PORTDbits.RD7
#define ch3ext    PORTCbits.RC7
#define clearext       PORTCbits.RC1
/* TURN LEDS ON AND OFF*/
#define ON1    LATEbits.LATE1 = 1;  /*Turn on chan1*/
#define OFF1   LATEbits.LATE1 = 0;  /*Turn off chan1*/
#define ON2    LATEbits.LATE0 = 1; /*Turn on chan2*/
#define OFF2   LATEbits.LATE0 = 0; /*Turn off chan2*/
#define ON3    LATGbits.LATG0 = 1; /*Turn on chan2*/
#define OFF3   LATGbits.LATG0 = 0;  /*Turn off chan2*/
#define FANON  LATEbits.LATE2 = 1;   /*Turn fan on*/
#define FANOFF LATEbits.LATE2 = 0;  /*Turn fan off*/
/*DEFINE INPUTS FROM DIPSWITCH*/
/*Note that the new board has pullups on the dipswitch,*/
/*whereas 550587 PCB had pull downs, thus logic is reversed.*/
uint8_t    dipsw1;
uint8_t    dipsw2;
uint8_t    dipsw3;
uint8_t    dipsw4;
uint8_t    dipsw5;
uint8_t    dipsw8;
uint8_t    dip8;   //bit0=dip1...
uint8_t    dip8_init;
uint8_t    extreg5;    //bit0=reset,bit1=ch1...etc, to bit4=clear
                            //external connector pins
uint8_t    extreg5_init;
uint8_t    extp3;    //reset
uint8_t    extp4;    //ch1
uint8_t    extp5;    //ch2
uint8_t    extp6;    //ch3
uint8_t    extp9;    //an in
uint8_t    extp10;   //clear
uint8_t    extp11;   //TRIP OUT
uint8_t    temp1;
uint8_t    temp2;
uint8_t    temp3;
uint8_t    tempb;
uint8_t    ana8;           //holds ADRESH
uint8_t    ana8_init;
uint8_t    max_led_temp;
uint8_t    max_pcb_temp;
uint8_t    board_90c;      //max board temp value
uint8_t    board_80c;
uint8_t    led_90c;
uint8_t    led_80c;        //max led temp value
uint8_t    ledthermopen;   //trip value when thermistor open
uint8_t    pcbthermopen;
uint8_t    currentint;        //represents 0A, 1.76A, 2.64A, 3.52A
                                //bit0=0,bit1=1a76...etc
uint8_t    iset_mcp4013;   //number of down pulses needed to get current.
uint8_t    mcp4013pulses;
uint8_t    i;
uint8_t    just_lsbmsb_init;
uint8_t    just_lsbmsb;
uint8_t    extreg5;
uint8_t    extp3;
uint8_t    extp4;
uint8_t    extp5;
uint8_t    extp6;
uint8_t    extp10;
uint8_t     triptempled;
uint8_t     triptempboard;
uint8_t     tripledthermopen;
uint8_t    ch1temp;
uint8_t    ch2temp;
uint8_t    ch3temp;
uint8_t    boardtemp;
uint8_t    analog_in;
uint8_t    analog_in_init;
void main(void) {
    disable_interrupts();
    disable_pullups();
    disable_opendrain();
    disable_comparators();
    setup_adc();
    setup_ports();
    NC_pins_low();  //make all NC pins low.
    here:
    while(1){
    OFF1;
    OFF2;
    OFF3;
    FANOFF;
    read_dips();
    read_temps();
    if (currentint == 1) {goto  here;}
    if (boardtemp > triptempboard) {goto    here;}
    here_1:
    if (dipsw1)  pre_internal();  //OFF (actually high) = INTERNAL MODE
    if (dipsw1)  internalmode();    //*************************
    if (dipsw1) {goto    here_1;}
    if (!dipsw1) pre_external();
    if (!dipsw1) externalmode();    //**************************
    goto    here_1;
    return;
void    set_ana_dig_ports(void){
    ANCON0 = 0xFC;
    ANCON1 = 0x0F;
    ANCON2 = 0x00;
    return;
void    disable_interrupts(void) {
    INTCON =0x00;
    INTCON2 =0x80;
    INTCON3 = 0x00;
    PIE1 = 0x00;
    PIE2 = 0x00;
    PIE3 = 0x00;
    PIE4 = 0x00;
    PIE5 = 0x00;
    PIE6 = 0x00;
    return;
void    disable_pullups(void){
    PADCFG1 = 0;
    return;
void    disable_opendrain(void){
    ODCON1 = 0;
    ODCON2 = 0;
    ODCON3 = 0;
    return;
void    disable_comparators(void){
    CM1CON = 0;
    CM2CON = 0;
    CM3CON = 0;
    return;
void    setup_adc(void){
    ADCON0 = 0;
    ADCON1 = 0x10;  //VREF
    ADCON2 = 0x3E;  // Left jus/Tacq
    return;
void    setup_ports(void){
    TRISA =   0x2C;
    TRISB   = 0x3F;
    TRISC   = 0xA2;
    TRISD   = 0xD0;
    TRISE   = 0x40;
    TRISF   = 0xFE;
    TRISG   = 0x24;
    return;
void    NC_pins_low(void){
//Make all NC pins low (they are already made to outputs)
//They are outputs for noise immunity reasons.
    LATAbits.LATA0 = 0;
    LATAbits.LATA1 = 0;
    LATAbits.LATA6 = 0;
    LATAbits.LATA7 = 0;
    LATBbits.LATB6  = 0;    //PGC
    LATBbits.LATB7  = 0;    //PGD
    LATCbits.LATC0 = 0;
    LATCbits.LATC6 = 0;
    LATDbits.LATD0 = 0;
    LATDbits.LATD1 = 0;
    LATDbits.LATD2 = 0;
    LATDbits.LATD3 = 0;
    LATDbits.LATD4 = 0;
    LATEbits.LATE2 = 0;
    LATEbits.LATE3 = 0;
    LATEbits.LATE5 = 0;
    LATEbits.LATE7 = 0;
    LATGbits.LATG1 = 0;
    LATGbits.LATG3 = 0;
    LATGbits.LATG4 = 0;
    return;
void    read_extreg5(void){
    //read just the five digital inputs from ext conn.
    //put them in extreg5;
    extreg5 = 0x00;    //first 5 bits of ext5 holds ext conn res,1,2,3,cl
    if (resetext) {extp3 = 0x01; extreg5 = extreg5 || 0x01;}
    else    {extp3 = 0x00;}
    if (ch1ext) {extp4 = 0x01; extreg5 = extreg5 || 0x02;}
    else    {extp4 = 0x00;}
    if (ch2ext) {extp5 = 0x01; extreg5 = extreg5 || 0x04;}
    else    {extp5 = 0x00;}
    if (ch3ext) {extp6 = 0x01; extreg5 = extreg5 || 0x08;}
    else    {extp6 = 0x00;}
    if (clearext) {extp10 = 0x01; extreg5 = extreg5 || 0x10;}
    else    {extp10 = 0x00;}
    return;
void    read_dips(void){
    //dip8 holds the state of dipswitch in correcponding bit places.
    dip8 = 0x00;
    if (dip1pin) {dipsw1 = 0x01; dip8 = dip8 || 0x01;}
    else    {dipsw1 = 0x00;}
    if (dip2pin) {dipsw2 = 0x01; dip8 = dip8 || 0x02;}
    else    {dipsw2 = 0x00;}
    if (dip3pin) {dipsw3 = 0x01; dip8 = dip8 || 0x04;}
    else    {dipsw3 = 0x00;}
    if (dip4pin) {dipsw4 = 0x01; dip8 = dip8 || 0x08;}
    else    {dipsw4 = 0x00;}
    if (dip5pin) {dipsw5 = 0x01; dip8 = dip8 || 0x10;}
    else    {dipsw5 = 0x00;}
    if (dip8pin) {dipsw8 = 0x01; dip8 = dip8 || 0x80;}
    else    {dipsw8 = 0x00;}
    if (!dipsw2 && !dipsw3) {currentint = 4;}   //3.52A
    if (dipsw2 && !dipsw3)  {currentint = 3;}   //2.64A
    if (!dipsw2 && dipsw3)  {currentint = 2;}   //1.76A
    if (dipsw2 && dipsw3)   {currentint = 1;}   //SHUTDOWN (0A)
    if (!dipsw5) {triptempled = 200;}  //90degc (Thermistor)
    if (dipsw5)  {triptempled = 168;}  //80degc (Thermistor)
    triptempboard = 184; //90degC = board trip temperature. MCP9701A
    tripledthermopen = 10;  //For when LED thermistor goes open.
    return;
void    read_analog(void){
    ADCON0 = 0x19;  //turn on ADC module FOR AN6 (0-10V)
    ADCON0 = 0x1B;  //START ADC CONVERSION
    while(GODONE) {;}   //Wait till conversion complete.
    ana8 = ADRESH;
    analog_in = ana8;
    ADCON0 = 0x18;  //turn off ADC MODULE.
    return;
void    read_temps(void){
    ADCON0 = 0x05;  //turn on ADC module FOR AN4 (therm ch1)
    ADCON0 = 0x07;  //START ADC CONVERSION
    ana8 = ADRESH;
    ch1temp = ana8;
    ADCON0 = 0x04;  //turn off ADC MODULE.
    ADCON0 = 0x29;  //turn on ADC module FOR AN10 (therm ch2)
    ADCON0 = 0x2B;  //START ADC CONVERSION
    ana8 = ADRESH;
    ch2temp = ana8;
    ADCON0 = 0x28;  //turn off ADC MODULE.
    ADCON0 = 0x2D;  //turn on ADC module FOR AN11 (therm ch3)
    ADCON0 = 0x2F;  //START ADC CONVERSION
    ana8 = ADRESH;
    ch3temp = ana8;
    ADCON0 = 0x2C;  //turn off ADC MODULE.
    ADCON0 = 0x1D;  //turn on ADC module FOR AN7 (Board thermistor,MCP9701A)
    ADCON0 = 0x1F;  //START ADC CONVERSION
    ana8 = ADRESH;
    boardtemp = ana8;
    ADCON0 = 0x1C;  //turn off ADC MODULE.
    return;
void    set_initials_int(void){
    read_dips();
    dip8_init = dip8;                   //for comparison later
    return;
void    set_initials_ext(void){
    read_dips();
    read_extreg5();
    extreg5_init = extreg5;
    read_analog();       //read the 0-10v signal.
    analog_in_init = analog_in;   //0-10V signal
return;
void    pre_internal(void){
    set_initials_int();
    set_current_int();
    return;
void    pre_external(void){
    set_initials_ext();
    if (dipsw4) {set_current_ext_AH();}
    if (!dipsw4) {set_current_ext_AL();}
    return;
void    internalmode(void){
    FANON;
    while(1){
    //__delay_ms(100);
    read_dips();
    if (dip8 != dip8_init) {break;}
    read_temps();
    if (boardtemp > triptempboard){break;}
    if (ch1temp < triptempled) {ON1;}
    if (ch2temp < triptempled) {ON2;}
    if (ch3temp < triptempled) {ON3;}
    if (ch1temp >= triptempled) {OFF1;}
    if (ch2temp >= triptempled) {OFF2;}
    if (ch3temp >= triptempled) {OFF3;}
return;}
void    externalmode(void) {
    FANON;
        while(1){
    //__delay_ms(100);
    read_dips();
    read_extreg5();
    if (extreg5 != extreg5_init){break;}
    read_analog();
    if (analog_in != analog_in_init) {break;}
    read_temps();
    if (boardtemp > triptempboard) {break;}
    if ((extp3 == 1) && (ch1temp < triptempled )) {ON1;}
    if ((extp3 == 1) && (ch2temp < triptempled )) {ON2;}
    if ((extp3 == 1) && (ch3temp < triptempled )) {ON3;}
    if ((extp3 == 0) || (ch1temp >= triptempled)) {OFF1;}
    if ((extp3 == 0) || (ch1temp >= triptempled)) {OFF2;}
    if ((extp3 == 0) || (ch1temp >= triptempled)) {OFF3;}
    return;
void    set_current_int(void){
    //set mcp4013 by topping the mcp4013, then decrementing
    if (currentint == 2) mcp4013pulses = 31;    //no. of downpulses.
    if (currentint == 3) mcp4013pulses = 17;
    if (currentint == 4) mcp4013pulses = 4;
    top_mcp4013();      //top out the mcp4013
    mcp4013_csout = 1;  //disable mcp4013
    mcp4013_csout = 1;
    mcp4013_udout = 0;  //ready to decrement
    mcp4013_udout = 0;
    mcp4013_csout = 0;  //enable mcp4013
    mcp4013_csout = 0;
    for (i== 0; i== mcp4013pulses; i++){
    mcp4013_udout = 1;  //pulse it to the level
    mcp4013_udout = 1;
    mcp4013_udout = 0;
    mcp4013_udout = 0;
    mcp4013_csout = 1;
    return;
void    top_mcp4013(void) {
        mcp4013_csout = 1;
        mcp4013_udout = 1;  //ready to increment wiper
        mcp4013_udout = 1;
        mcp4013_csout = 0;
        for(i==64;i==0;i--){
        mcp4013_udout = 0;
        mcp4013_udout = 0;
        mcp4013_udout = 1;
        mcp4013_udout = 1;
        mcp4013_csout = 1;
        return;
void    set_current_ext_AH(void){
    //This is to set the current in external mode when the 4th dipswitch
    //asks for the 0-10V signal to be "10V = Highest current"
    //["AH" stands for Active High"]
    //MCP4013pulses will here be the number of downpulses to pulse the digital
    //pot with. (starting from the top of the resistor 'chain')
    //Never go below 11 POT steps (ie, never below 0.176V -> 300mA)
    //Make max current correspond to 235bits to 255bits on the 0-10V input
    //(9.2V)
//CALCULATING NUMBER OF DOWNPULSES.
    if (currentint == 2) {
    //9 apart
    if  (analog_in >= 235)            {mcp4013pulses = 31;}
    if ((analog_in >= 225) && (analog_in <= 234)) {mcp4013pulses = 32;}
    if ((analog_in >= 215) && (analog_in <= 224)) {mcp4013pulses = 33;}
    if ((analog_in >= 205) && (analog_in <= 214)) {mcp4013pulses = 34;}
    if ((analog_in >= 195) && (analog_in <= 204)) {mcp4013pulses = 35;}
    if ((analog_in >= 185) && (analog_in <= 194)) {mcp4013pulses = 36;}
    if ((analog_in >= 175) && (analog_in <= 184)) {mcp4013pulses = 37;}
    if ((analog_in >= 165) && (analog_in <= 174)) {mcp4013pulses = 38;}
    if ((analog_in >= 155) && (analog_in <= 164)) {mcp4013pulses = 39;}
    if ((analog_in >= 145) && (analog_in <= 154)) {mcp4013pulses = 40;}
    if ((analog_in >= 135) && (analog_in <= 144)) {mcp4013pulses = 41;}
    if ((analog_in >= 125) && (analog_in <= 134)) {mcp4013pulses = 42;}
    if ((analog_in >= 115) && (analog_in <= 124)) {mcp4013pulses = 43;}
    if ((analog_in >= 105) && (analog_in <= 114)) {mcp4013pulses = 44;}
    if ((analog_in >= 95) && (analog_in <= 104))  {mcp4013pulses = 45;}
    if ((analog_in >= 85) && (analog_in <= 94))   {mcp4013pulses = 46;}
    if ((analog_in >= 75) && (analog_in <= 84))   {mcp4013pulses = 47;}
    if ((analog_in >= 65) && (analog_in <= 74))   {mcp4013pulses = 48;}
    if ((analog_in >= 55) && (analog_in <= 64))   {mcp4013pulses = 49;}
    if ((analog_in >= 45) && (analog_in <= 54))   {mcp4013pulses = 50;}
    if ((analog_in >= 35) && (analog_in <= 44))   {mcp4013pulses = 51;}
    if ((analog_in >= 25) && (analog_in <= 34))   {mcp4013pulses = 52;}
    if ((analog_in >= 0) && (analog_in <= 24))    {mcp4013pulses = 53;}
    if (currentint == 3) {
     //6 apart
    if  (analog_in >= 235)            {mcp4013pulses = 17;}
    if ((analog_in >= 228) && (analog_in <= 234)) {mcp4013pulses = 18;}
    if ((analog_in >= 221) && (analog_in <= 227)) {mcp4013pulses = 19;}
    if ((analog_in >= 214) && (analog_in <= 220)) {mcp4013pulses = 20;}
    if ((analog_in >= 207) && (analog_in <= 213)) {mcp4013pulses = 21;}
    if ((analog_in >= 200) && (analog_in <= 206)) {mcp4013pulses = 22;}
    if ((analog_in >= 193) && (analog_in <= 199)) {mcp4013pulses = 23;}
    if ((analog_in >= 186) && (analog_in <= 192)) {mcp4013pulses = 24;}
    if ((analog_in >= 179) && (analog_in <= 185)) {mcp4013pulses = 25;}
    if ((analog_in >= 172) && (analog_in <= 178)) {mcp4013pulses = 26;}
    if ((analog_in >= 165) && (analog_in <= 171)) {mcp4013pulses = 27;}
    if ((analog_in >= 158) && (analog_in <= 164)) {mcp4013pulses = 28;}
    if ((analog_in >= 151) && (analog_in <= 157)) {mcp4013pulses = 29;}
    if ((analog_in >= 144) && (analog_in <= 150)) {mcp4013pulses = 30;}
    if ((analog_in >= 137) && (analog_in <= 143)) {mcp4013pulses = 31;}
    if ((analog_in >= 130) && (analog_in <= 136)) {mcp4013pulses = 32;}
    if ((analog_in >= 123) && (analog_in <= 129)) {mcp4013pulses = 33;}
    if ((analog_in >= 116) && (analog_in <= 122)) {mcp4013pulses = 34;}
    if ((analog_in >= 109) && (analog_in <= 115)) {mcp4013pulses = 35;}
    if ((analog_in >= 102) && (analog_in <= 108)) {mcp4013pulses = 36;}
    if ((analog_in >= 95) && (analog_in <= 101))  {mcp4013pulses = 37;}
    if ((analog_in >= 88) && (analog_in <= 94))   {mcp4013pulses = 38;}
    if ((analog_in >= 81) && (analog_in <= 87))   {mcp4013pulses = 39;}
    if ((analog_in >= 74) && (analog_in <= 80))   {mcp4013pulses = 40;}
    if ((analog_in >= 67) && (analog_in <=73))    {mcp4013pulses = 41;}
    if ((analog_in >= 60) && (analog_in <= 66))   {mcp4013pulses = 42;}
    if ((analog_in >= 53) && (analog_in <= 59))   {mcp4013pulses = 43;}
    if ((analog_in >= 46) && (analog_in <= 52))   {mcp4013pulses = 44;}
    if ((analog_in >= 39) && (analog_in <= 45))   {mcp4013pulses = 45;}
    if ((analog_in >= 32) && (analog_in <= 38))   {mcp4013pulses = 46;}
    if ((analog_in >= 25) && (analog_in <= 31))   {mcp4013pulses = 47;}
    if ((analog_in >= 18) && (analog_in <= 24))   {mcp4013pulses = 48;}
    if ((analog_in >= 11) && (analog_in <= 17))   {mcp4013pulses = 49;}
    if ((analog_in >= 4) &&  (analog_in <= 10))   {mcp4013pulses = 50;}
    if ((analog_in >= 0) &&  (analog_in <= 3))    {mcp4013pulses = 50;}
    if (currentint == 4){
    //4 apart
    if  (analog_in >= 235)                   {mcp4013pulses = 4;}
    if ((analog_in >= 230) && (analog_in <= 234)) {mcp4013pulses = 5;}
    if ((analog_in >= 225) && (analog_in <= 229)) {mcp4013pulses = 6;}
    if ((analog_in >= 220) && (analog_in <= 224)) {mcp4013pulses = 7;}
    if ((analog_in >= 215) && (analog_in <= 219)) {mcp4013pulses = 8;}
    if ((analog_in >= 210) && (analog_in <= 214)) {mcp4013pulses = 9;}
    if ((analog_in >= 205) && (analog_in <= 209)) {mcp4013pulses = 10;}
    if ((analog_in >= 200) && (analog_in <= 204)) {mcp4013pulses = 11;}
    if ((analog_in >= 195) && (analog_in <= 199)) {mcp4013pulses = 12;}
    if ((analog_in >= 190) && (analog_in <= 194)) {mcp4013pulses = 13;}
    if ((analog_in >= 185) && (analog_in <= 189)) {mcp4013pulses = 14;}
    if ((analog_in >= 180) && (analog_in <= 184)) {mcp4013pulses = 15;}
    if ((analog_in >= 175) && (analog_in <= 179)) {mcp4013pulses = 16;}
    if ((analog_in >= 170) && (analog_in <= 174)) {mcp4013pulses = 17;}
    if ((analog_in >= 165) && (analog_in <= 169)) {mcp4013pulses = 18;}
    if ((analog_in >= 160) && (analog_in <= 164)) {mcp4013pulses = 19;}
    if ((analog_in >= 155) && (analog_in <= 159)) {mcp4013pulses = 20;}
    if ((analog_in >= 150) && (analog_in <= 154)) {mcp4013pulses = 21;}
    if ((analog_in >= 145) && (analog_in <= 149)) {mcp4013pulses = 22;}
    if ((analog_in >= 140) && (analog_in <= 144)) {mcp4013pulses = 23;}
    if ((analog_in >= 135) && (analog_in <= 139)) {mcp4013pulses = 24;}
    if ((analog_in >= 130) && (analog_in <= 134)) {mcp4013pulses = 25;}
    if ((analog_in >= 125) && (analog_in <= 129)) {mcp4013pulses = 26;}
    if ((analog_in >= 120) &&  (analog_in <= 124)) {mcp4013pulses = 27;}
    if ((analog_in >= 115) &&  (analog_in <= 119))  {mcp4013pulses = 28;}
    if ((analog_in >= 110) &&  (analog_in <= 114))  {mcp4013pulses = 29;}
    if ((analog_in >= 105) &&  (analog_in <= 109))  {mcp4013pulses = 30;}
    if ((analog_in >= 100) &&  (analog_in <= 104))  {mcp4013pulses = 31;}
    if ((analog_in >= 95) &&  (analog_in <= 99))  {mcp4013pulses = 32;}
    if ((analog_in >= 90) &&  (analog_in <= 94))  {mcp4013pulses = 33;}
    if ((analog_in >= 85) &&  (analog_in <= 89))  {mcp4013pulses = 34;}
    if ((analog_in >= 80) &&  (analog_in <= 84))  {mcp4013pulses = 35;}
    if ((analog_in >= 75) &&  (analog_in <= 79))  {mcp4013pulses = 36;}
    if ((analog_in >= 70) &&  (analog_in <= 74))  {mcp4013pulses = 37;}
    if ((analog_in >= 65) &&  (analog_in <= 69))  {mcp4013pulses = 38;}
    if ((analog_in >= 60) &&  (analog_in <= 64))  {mcp4013pulses = 39;}
    //3 apart
    if ((analog_in >= 56) &&  (analog_in <= 59))  {mcp4013pulses = 40;}
    if ((analog_in >= 52) &&  (analog_in <= 55))  {mcp4013pulses = 41;}
    if ((analog_in >= 48) &&   (analog_in <= 51)) {mcp4013pulses = 42;}
    if ((analog_in >= 44) &&   (analog_in <= 47)) {mcp4013pulses = 43;}
    if ((analog_in >=40) &&  (analog_in <= 43))   {mcp4013pulses = 39;}
    if ((analog_in >= 36) &&  (analog_in <= 39))  {mcp4013pulses = 40;}
    if ((analog_in >= 32) &&  (analog_in <= 35))  {mcp4013pulses = 41;}
    if ((analog_in >= 28) &&   (analog_in <= 31))  {mcp4013pulses = 42;}
    if ((analog_in >= 24) &&   (analog_in <= 27))   {mcp4013pulses = 43;}
    if ((analog_in >= 20) &&  (analog_in <= 23))  {mcp4013pulses =44;}
    if ((analog_in >= 16) &&  (analog_in <= 19))  {mcp4013pulses = 45;}
    if ((analog_in >= 12) &&  (analog_in <= 15))  {mcp4013pulses = 46;}
    if ((analog_in >= 8) &&   (analog_in <= 11))   {mcp4013pulses = 47;}
    if ((analog_in >= 4) &&  (analog_in <= 7))    {mcp4013pulses =48;}
    if ((analog_in >= 0) &&  (analog_in <= 3))    {mcp4013pulses = 49;}
    mcp4013_csout = 1;
    mcp4013_udout = 0;
    mcp4013_csout = 0;
    mcp4013_udout = 1;
    mcp4013_udout = 0;
    mcp4013_udout = 0;
    mcp4013_csout = 1;
    return;
void    set_current_ext_AL(void){
    //asks for the 0-10V signal to be "0V = Highest current"
    //["AL" stands for Active Low"]
    //Make max current correspond to 0 bits to 9 bits on the 0-10V input
    //(ie anything below 0.3V will be max)
    //12 apart
    if  (analog_in <= 9)             {mcp4013pulses = 31;}
    if ((analog_in >= 10  ) && (analog_in <= 22))  {mcp4013pulses = 32;}
    if ((analog_in >= 23  ) && (analog_in <= 35))  {mcp4013pulses = 33;}
    if ((analog_in >= 36  ) && (analog_in <= 48))  {mcp4013pulses = 34;}
    if ((analog_in >= 49  ) && (analog_in <= 61))  {mcp4013pulses = 35;}
    if ((analog_in >= 62  ) && (analog_in <= 74))  {mcp4013pulses = 36;}
    if ((analog_in >= 75  ) && (analog_in <= 87))  {mcp4013pulses = 37;}
    if ((analog_in >= 88  ) && (analog_in <= 100))  {mcp4013pulses = 38;}
    if ((analog_in >= 101  ) && (analog_in <= 113))  {mcp4013pulses = 39;}
    if ((analog_in >= 114  ) && (analog_in <= 126))  {mcp4013pulses = 40;}
    if ((analog_in >= 127  ) && (analog_in <= 139))  {mcp4013pulses = 41;}
    if ((analog_in >= 140 ) && (analog_in <= 152))  {mcp4013pulses = 42;}
    if ((analog_in >= 153  ) && (analog_in <= 165)) {mcp4013pulses = 43;}
    if ((analog_in >= 166  ) && (analog_in <= 178)) {mcp4013pulses = 44;}
    if ((analog_in >= 179  ) && (analog_in <= 191)) {mcp4013pulses = 45;}
    if ((analog_in >= 192 )  && (analog_in <= 204)) {mcp4013pulses = 46;}
    if ((analog_in >= 205  ) && (analog_in <= 217)) {mcp4013pulses = 47;}
    if ((analog_in >= 218  ) && (analog_in <= 230)) {mcp4013pulses = 48;}
    if ((analog_in >= 231  ) && (analog_in <= 243)) {mcp4013pulses = 49;}
    if ((analog_in >= 244 )  && (analog_in <= 255)) {mcp4013pulses = 50;}
    //7 apart
    if      (analog_in <= 9)     {mcp4013pulses = 17;}
    if ((analog_in >= 10  )  && (analog_in <= 17))   {mcp4013pulses = 18;}
    if ((analog_in >= 18  )  && (analog_in <= 25))   {mcp4013pulses = 19;}
    if ((analog_in >= 26  )  && (analog_in <= 33))   {mcp4013pulses = 20;}
    if ((analog_in >= 34  )  && (analog_in <= 41))   {mcp4013pulses = 21;}
    if ((analog_in >= 42  )  && (analog_in <= 49))   {mcp4013pulses = 22;}
    if ((analog_in >= 50  )  && (analog_in <= 57))   {mcp4013pulses = 23;}
    if ((analog_in >= 58  )  && (analog_in <= 65))   {mcp4013pulses = 24;}
    if ((analog_in >= 66  )  && (analog_in <= 73))   {mcp4013pulses = 25;}
    if ((analog_in >= 74  )  && (analog_in <= 81))   {mcp4013pulses = 26;}
    if ((analog_in >= 82  )  && (analog_in <= 89))   {mcp4013pulses = 27;}
    if ((analog_in >= 90  )  && (analog_in <= 97))   {mcp4013pulses = 28;}
    if ((analog_in >= 98  )  && (analog_in <= 105))  {mcp4013pulses = 29;}
    if ((analog_in >= 106 )  && (analog_in <= 113))  {mcp4013pulses = 30;}
    if ((analog_in >= 114  )  && (analog_in <= 121)) {mcp4013pulses = 31;}
    if ((analog_in >= 122  )  && (analog_in <= 129)) {mcp4013pulses = 32;}
    if ((analog_in >= 130  )  && (analog_in <= 137)) {mcp4013pulses = 33;}
    if ((analog_in >= 138  )  && (analog_in <= 145)) {mcp4013pulses = 34;}
    if ((analog_in >= 146  )  && (analog_in <= 153)) {mcp4013pulses = 35;}
    if ((analog_in >= 154 )  && (analog_in <= 161))  {mcp4013pulses = 36;}
    if ((analog_in >= 162  )  && (analog_in <= 169)) {mcp4013pulses = 37;}
    if ((analog_in >= 170  )  && (analog_in <= 177)) {mcp4013pulses = 38;}
    if ((analog_in >= 178  )  && (analog_in <= 185)) {mcp4013pulses = 39;}
    if ((analog_in >= 186 )  && (analog_in <= 193))  {mcp4013pulses = 40;}
    if ((analog_in >= 194 )  && (analog_in <= 201))  {mcp4013pulses = 41;}
    if ((analog_in >= 202  )  && (analog_in <= 209)) {mcp4013pulses = 42;}
    if ((analog_in >= 210  )  && (analog_in <= 217)) {mcp4013pulses = 43;}
    if ((analog_in >= 218  )  && (analog_in <= 225)) {mcp4013pulses = 44;}
    if ((analog_in >= 226 )  && (analog_in <= 233))  {mcp4013pulses = 45;}
    if ((analog_in >= 234 )  && (analog_in <= 241))  {mcp4013pulses = 46;}
    if ((analog_in >= 242  )  && (analog_in <= 249)) {mcp4013pulses = 47;}
    if ((analog_in >= 250  )  && (analog_in <= 255)) {mcp4013pulses = 48;}
    if (currentint == 4)    {
    //4 apart
    if           (analog_in <= 9)    {mcp4013pulses = 4;}
    if ((analog_in >= 10  )  && (analog_in <= 14))   {mcp4013pulses = 5;}
    if ((analog_in >= 15  )  && (analog_in <= 19))   {mcp4013pulses = 6;}
    if ((analog_in >= 20  )  && (analog_in <= 24))   {mcp4013pulses = 7;}
    if ((analog_in >= 25  )  && (analog_in <= 29))   {mcp4013pulses = 8;}
    if ((analog_in >= 30  )  && (analog_in <= 34))   {mcp4013pulses = 9;}
    if ((analog_in >= 35  )  && (analog_in <= 39))   {mcp4013pulses = 10;}
    if ((analog_in >= 40  )  && (analog_in <= 44))   {mcp4013pulses = 11;}
    if ((analog_in >= 45  )  && (analog_in <= 49))   {mcp4013pulses = 12;}
    if ((analog_in >= 50  )  && (analog_in <= 54))   {mcp4013pulses = 13;}
    if ((analog_in >= 55  )  && (analog_in <= 59))   {mcp4013pulses = 14;}
    if ((analog_in >= 60  )  && (analog_in <= 64))   {mcp4013pulses = 15;}
    if ((analog_in >= 65  )  && (analog_in <= 69))  {mcp4013pulses = 16;}
    if ((analog_in >= 70  )  && (analog_in <= 74))   {mcp4013pulses = 17;}
    if ((analog_in >= 75  )  && (analog_in <= 79))   {mcp4013pulses = 18;}
    if ((analog_in >= 80  )  && (analog_in <= 84))   {mcp4013pulses = 19;}
    if ((analog_in >= 85  )  && (analog_in <= 89))   {mcp4013pulses = 20;}
    if ((analog_in >= 90  )  && (analog_in <= 94))   {mcp4013pulses = 21;}
    if ((analog_in >= 95  )  && (analog_in <= 99))   {mcp4013pulses = 22;}
    if ((analog_in >= 100  )  && (analog_in <= 104))   {mcp4013pulses = 23;}
    if ((analog_in >= 105  )  && (analog_in <= 109))   {mcp4013pulses = 24;}
    if ((analog_in >= 110  )  && (analog_in <= 114))   {mcp4013pulses = 25;}
    if ((analog_in >= 115  )  && (analog_in <= 119))   {mcp4013pulses = 26;}
    if ((analog_in >= 120  )  && (analog_in <= 124))   {mcp4013pulses = 27;}
    if ((analog_in >= 125  )  && (analog_in <= 129))   {mcp4013pulses = 28;}
    if ((analog_in >= 130  )  && (analog_in <= 134))   {mcp4013pulses = 29;}
    if ((analog_in >= 135  )  && (analog_in <= 139))   {mcp4013pulses = 30;}
    if ((analog_in >= 140  )  && (analog_in <= 144))   {mcp4013pulses = 31;}
    if ((analog_in >= 145  )  && (analog_in <= 149))   {mcp4013pulses = 32;}
    if ((analog_in >= 150  )  && (analog_in <= 154))   {mcp4013pulses = 33;}
    if ((analog_in >= 155  )  && (analog_in <= 159))   {mcp4013pulses = 34;}
    if ((analog_in >= 160  )  && (analog_in <= 164))   {mcp4013pulses = 35;}
    if ((analog_in >= 165  )  && (analog_in <= 169))   {mcp4013pulses = 36;}
    if ((analog_in >= 170  )  && (analog_in <= 174))   {mcp4013pulses = 37;}
    if ((analog_in >= 175  )  && (analog_in <= 179))   {mcp4013pulses = 38;}
    if ((analog_in >= 180  )  && (analog_in <= 184))   {mcp4013pulses = 39;}
    if ((analog_in >= 185  )  && (analog_in <= 189))   {mcp4013pulses = 40;}
    if ((analog_in >= 190  )  && (analog_in <= 194))   {mcp4013pulses = 41;}
    if ((analog_in >= 195  )  && (analog_in <= 199))   {mcp4013pulses = 42;}
    if ((analog_in >= 200  )  && (analog_in <= 204))   {mcp4013pulses = 43;}
    if ((analog_in >= 205  )  && (analog_in <= 209))   {mcp4013pulses = 44;}
    if ((analog_in >= 210  )  && (analog_in <= 214))   {mcp4013pulses = 45;}
    if ((analog_in >= 215  )  && (analog_in <= 219))   {mcp4013pulses = 46;}
    if ((analog_in >= 220  )  && (analog_in <= 224))   {mcp4013pulses = 47;}
    if ((analog_in >= 225  )  && (analog_in <= 229))   {mcp4013pulses = 48;}
    if ((analog_in >= 230  )  && (analog_in <= 234))   {mcp4013pulses = 49;}
    if ((analog_in >= 235  )  && (analog_in <= 239))   {mcp4013pulses = 50;}
    if ((analog_in >= 240  )  && (analog_in <= 244))   {mcp4013pulses = 51;}
    if ((analog_in >= 245  )  && (analog_in <= 249))   {mcp4013pulses = 52;}
    if ((analog_in >= 250  )  && (analog_in <= 255))   {mcp4013pulses = 53;}
    mcp4013_csout = 1;
    mcp4013_udout = 0;
    mcp4013_csout = 0;
    mcp4013_udout = 1;
    mcp4013_udout = 0;
    mcp4013_udout = 0;
    mcp4013_csout = 1;
return;
thanks, but I am not using a crystal...and the command "_XTAL_FREQ" implies that a crystal is being used?
No... Its just used to acertain __delay_ms() and __delay_us() routines...
