MCLRE: RA3/MCLR pin function select(5)
1 = RA3/MCLR pin function is MCLR
bit 13-12 BG1:BG0: Bandgap Calibration bits for BOD and POR voltage(1)
00 = Lowest bandgap voltage
11 = Highest bandgap voltage
;include "P16F676.inc" ;include the defaults for the chip
__config 0x3114 ;sets the configuration settings (oscillator type etc.)
; HERE SET TO INTERNAL OSCILLATOR 4MHZ
ORG 0
GOTO INIT
INIT
CLRF OPTION_REG
BSF STATUS,RP0
CLRF VRCON
MOVLW 0x3f
MOVWF TRISA ; porta as input
MOVLW 0x0
CLRF ANSEL ; disable ADC
MOVWF TRISC ; portb as output
BCF STATUS,RP0
MOVLW 0x7
MOVWF CMCON
START
btfss PORTA,1 ; test bit 1
call delay
GOTO START
delay
movlw 0xff
movwf PORTC
movlw 0fh
movwf 0x21
dECfsz 0x21,f
clrf PORTC
RETURN
end
ORG 0
GOTO INIT
please explain more this part of code...
CLRF OPTION_REG??
CLRF VRCON??
bit 3 CIS: Comparator Input Switch bit
When CM2:CM0 = 110 or 101:
1 = VIN- connects to CIN+
0 = VIN- connects to CIN
ORG 0
GOTO INIT
INIT
CLRF OPTION_REG
BSF STATUS,RP0
CLRF VRCON
MOVLW 0x3f
MOVLW 0x0
BCF STATUS,RP0
MOVLW 0x7
MOVWF CMCON
START
call delay
GOTO START
delay
movlw 0xff
movwf PORTC
movlw 0fh
movwf 0x21
again: dECfsz 0x21,f
call again
clrf PORTC
RETURN
end
ORG 0
GOTO INIT
INIT
CLRF OPTION_REG
BSF STATUS,RP0
CLRF VRCON
MOVLW 0x3f
MOVLW 0x0
BCF STATUS,RP0
MOVLW 0x7
MOVWF CMCON
START
call delay
GOTO START
delay
movlw 0xff
movwf PORTC
movlw 0fh
movwf 0x21
dECfsz 0x21,f
clrf PORTC
RETURN
end
The decfsz is NOT being used a Conditional Instruction!!
Hi again,
Then i think there is no use of it!!
