You could test a couple of dozen capacitors of a known value and increase the voltage until greater leakage current is noted, this will increase as you surpass it's voltage limit, compare this to similar leakage currents on the known diodes at the same voltages and you should be able to approximate the value, but it be pretty painstaking.
