How to translate wire.requestfrom (arduino) to c?
Have you noticed that the datasheet says that the device address is 0x46. You are using 0x8C.
I tried using at the beginning 0x46, but failed to write to the GLCD.
Then I guess it's the 7-bit address - so for WRITE i used 0x8C (which is shifting 0x46 1 step left) - and it worked.
Oh, yes.. that is one thing that should be mentioned in the datasheet. At least when they represent it as a hexadecimal. Hex value strongly implies an 8 bit bit-pattern. Some (most?) datasheets include the R/W bit in the address. Officially the address is 7bits of course.
Hi T,
I tried reading the FW, and I read 0x01.
I still haven't tried the delays, however 0x01 sounds suspicious, i'm not sure it is the actual FW version of the GLCD.
Hi T,
I think that sounds promising at least. Better than zero. Sucks that they don't give any info about firmware versions in the datasheet.
Play with the delays. I saw this one thread where the code had 500ms delays between different drawing instruction. And he also had 500ms delay before he did anything... to let the glcd initialize.
well, I tried so many delays, but I keep reading zeros.
I also tried as you suggested to place other commands between the "Write Cursor" and "Read Cursor", but failed.
something is wrong with this GLCD or with its manual.
