Can the “Programmable switch mode controller” in the PIC16F1789 microcontroller provide a PWM output which is anything up to 25KHz, and with a duty cycle between 10% and 100%? (to control a 48V fan with)
PIC16F1789 microcontroller datasheet:
https://ww1.microchip.com/downloads/en/DeviceDoc/41675A.pdf
Can I also have (simultaneously , on a different pin), a 200KHz , 50% duty cycle square wave output from the PWM module? (aswell as the above 25KHz PWM output.)
Also what is the difference between a “PWM channel” and a “PWM output”? –And surely, if a microcontroller has a PWM output capability, then it must have a “PWM timebase”. –On the microchip microcontroller selector tool, it says I can’t have a “PWM timebase”, but I can have a “PWM output”…does that make any sense?
Microchip microcontroller selector tool:
https://www.microchip.com/maps/microcontroller.aspx
