How to use Interrupt in PIC16F877A in C..??
If you have the font in external file you need to reference it first.
If i will do that then it must be saved in PIC memory also??
In this code the font is saved in E2PROM it work well but the speed was getting slow and LED was Blinking..so, i am deciding to use Program memory i.e. Flash memory..
but the syntax is showing error..??
FLASH_WRITE(address,value);
OK, i will try first pls help me with flash memory issue how to use when i wrote any function name suffix with @addr it work..
but how to save data in it??
You don't have to.......when you have your project open in MPLAB... where the source file are shown on the left... just include the "font1.c"... If the font is declared as "const unsigned char" then it will be place in program memory... You then place the external declaration that I gave you in the main c file....
Try to view this.... Its the whole of tutorial 13 using MPLAB and ISIS..
You should see what I have done to place the code in code space..
OK, first i have to save font file file in MP LAB folder with .C and "const unsigned char"....then what to do?
if my code are written in other file like MATRIX.C then how to include it...and you are telling to store as .C but header file are in .H, pls explain this...
I wish I could get time to do a video... You don't need a header.
If you have a file in your build with only one item... ie.. the 2d array..
const unsigned char Font1[] = {
   1,2,3,4,5,6,7,8,
   1,2,3,4,5,6,7,8,
   1,2,3,4,5,6,7,8,
   1,2,3,4,5,6,7,8,
   1,2,3,4,5,6,7,8,
   1,2,3,4,5,6,7,8};
saved as "matrix.c"..... when you write your main code, you just reference it.
#include <headers.h>
#define stuff // config, xtal etc...
external const unsigned char Font1[];  //<<-- declare as external here....
void main()
    unsigned char x;
    x = Font1[3];   // <<<--- this will access the array in matrix.c.
That's pretty much all you need to do..
Declaring an int will waste memory..
Can you explain more on this the space used is not clear to me as there is only 8bit on memory per addr.. so, how will the memory wasted??
An int is defined in C as a word.... Two Bytes!! An unsigned char is One Byte... You are using a byte array not an int array... If it where declared as an int array it would be twice as big as it needs to be... If you are using the free version of Hitech...( I assume you are ) Hitech already double your ram usage anyway....
Flash IS program memory... Same stuff... The Pic has 8 k of FLASH code space 368 bytes of RAM space and 255 bytes of EEprom space.
const char = code (flash)... char = ram... eeprom is char as well but YOU need to retrieve it.
OK, As i was talking about matrix display i want your suggestion which method should i use for scanning rows i have got 270 LED 3mm RED colours...??
1. 3 to 8 decoder
2. 4017
3. Or direct to PORTB,???
An 8x8 matrix has 64 led's... I take it you want more 8 x 8 ( 270 red led's) The best way is to use column diving..the same way they do it in the ks0107 chip.
If you try to run two matrices you will need 16 column drivers (easily done by the pic16f877a ) If you implement some sort of shift register you can drive more columns BUT the difficulty come when the LED aren't lit for long enough for you to see...
EG.. Driving 2 seven segment units is simple enough.. When driving 4 it becomes apparent that the on off time is depreciating.... Driving 8... then you really need to up the led brightness so the visibility would be better... not only do people use shift registers... They use line drivers as well. You can use super bight LED's then.
One full line lit directly from a pic.... 100mA per port... 8 bits = 12.5mA per LED... You can argue that you are sourcing from one port and sinking on another. But mA's are mA's.
In reality you should have row drivers AND column drivers so the pic won't suffer..
See here.. Someone using a shift register ( with the code )... **broken link removed**
here is my PCB layout any suggestion will be appreciated...
The link you have provided is using single shift register....i was thinking to use 4to16 decoder with bc547 BJT...will it work...??
Hi, as per you suggestion i have used this
// Declare and Init the font array data
const unsigned char Font1[32][7] = {
   {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,}   // 0x20, Space
   {0x04, 0x04, 0x04, 0x04, 0x04, 0x00, 0x04,}   // 0x21, !
   {0x09, 0x09, 0x12, 0x00, 0x00, 0x00, 0x00,}   // 0x22, "
   {0x0a, 0x0a, 0x1f, 0x0a, 0x1f, 0x0a, 0x0a,}   // 0x23, #
   {0x04, 0x0f, 0x14, 0x0e, 0x05, 0x1e, 0x04,}   // 0x24, $
   {0x19, 0x19, 0x02, 0x04, 0x08, 0x13, 0x13,}   // 0x25, %
   {0x04, 0x0a, 0x0a, 0x0a, 0x15, 0x12, 0x0d,}   // 0x26, &
   {0x04, 0x04, 0x08, 0x00, 0x00, 0x00, 0x00,}   // 0x27, '
   {0x02, 0x04, 0x08, 0x08, 0x08, 0x04, 0x02,}   // 0x28, (
   {0x08, 0x04, 0x02, 0x02, 0x02, 0x04, 0x08,}   // 0x29, )
   {0x04, 0x15, 0x0e, 0x1f, 0x0e, 0x15, 0x04,}   // 0x2a, *
   {0x00, 0x04, 0x04, 0x1f, 0x04, 0x04, 0x00,}   // 0x2b, +
   {0x00, 0x00, 0x00, 0x00, 0x04, 0x04, 0x08,}   // 0x2c, ,
   {0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00,}   // 0x2d, -
   {0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x0c,}   // 0x2e, .
   {0x01, 0x01, 0x02, 0x04, 0x08, 0x10, 0x10,}   // 0x2f, /
   {0x0e, 0x11, 0x13, 0x15, 0x19, 0x11, 0x0e,}   // 0x30, 0
   {0x04, 0x0c, 0x04, 0x04, 0x04, 0x04, 0x0e,}   // 0x31, 1
   {0x0e, 0x11, 0x01, 0x02, 0x04, 0x08, 0x1f,}   // 0x32, 2
   {0x0e, 0x11, 0x01, 0x06, 0x01, 0x11, 0x0e,}   // 0x33, 3
   {0x02, 0x06, 0x0a, 0x12, 0x1f, 0x02, 0x02,}   // 0x34, 4
   {0x1f, 0x10, 0x1e, 0x01, 0x01, 0x11, 0x0e,}   // 0x35, 5
   {0x06, 0x08, 0x10, 0x1e, 0x11, 0x11, 0x0e,}   // 0x36, 6
   {0x1f, 0x01, 0x02, 0x04, 0x08, 0x08, 0x08,}   // 0x37, 7
   {0x0e, 0x11, 0x11, 0x0e, 0x11, 0x11, 0x0e,}   // 0x38, 8
   {0x0e, 0x11, 0x11, 0x0f, 0x01, 0x02, 0x0c,}   // 0x39, 9
   {0x00, 0x0c, 0x0c, 0x00, 0x0c, 0x0c, 0x00,}   // 0x3a, :
   {0x00, 0x0c, 0x0c, 0x00, 0x0c, 0x04, 0x08,}   // 0x3b, ;
   {0x02, 0x04, 0x08, 0x10, 0x08, 0x04, 0x02,}   // 0x3c, <
   {0x00, 0x00, 0x1f, 0x00, 0x1f, 0x00, 0x00,}   // 0x3d, =
   {0x08, 0x04, 0x02, 0x01, 0x02, 0x04, 0x08,}   // 0x3e, >
   {0x0e, 0x11, 0x01, 0x02, 0x04, 0x00, 0x04,}   // 0x3f, ?
const unsigned char Font2[32][7] = {
   {0x0e, 0x11, 0x17, 0x15, 0x17, 0x10, 0x0f,}   // 0x40, @
   {0x04, 0x0a, 0x11, 0x11, 0x1f, 0x11, 0x11,}   // 0x41, A
   {0x1e, 0x11, 0x11, 0x1e, 0x11, 0x11, 0x1e,}   // 0x42, B
   {0x0e, 0x11, 0x10, 0x10, 0x10, 0x11, 0x0e,}   // 0x43, C
   {0x1e, 0x09, 0x09, 0x09, 0x09, 0x09, 0x1e,}   // 0x44, D
   {0x1f, 0x10, 0x10, 0x1c, 0x10, 0x10, 0x1f,}   // 0x45, E
   {0x1f, 0x10, 0x10, 0x1f, 0x10, 0x10, 0x10,}   // 0x46, F
   {0x0e, 0x11, 0x10, 0x10, 0x13, 0x11, 0x0f,}   // 0x37, G
   {0x11, 0x11, 0x11, 0x1f, 0x11, 0x11, 0x11,}   // 0x48, H
   {0x0e, 0x04, 0x04, 0x04, 0x04, 0x04, 0x0e,}   // 0x49, I
   {0x1f, 0x02, 0x02, 0x02, 0x02, 0x12, 0x0c,}   // 0x4a, J
   {0x11, 0x12, 0x14, 0x18, 0x14, 0x12, 0x11,}   // 0x4b, K
   {0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x1f,}   // 0x4c, L
   {0x11, 0x1b, 0x15, 0x11, 0x11, 0x11, 0x11,}   // 0x4d, M
   {0x11, 0x11, 0x19, 0x15, 0x13, 0x11, 0x11,}   // 0x4e, N
   {0x0e, 0x11, 0x11, 0x11, 0x11, 0x11, 0x0e,}   // 0x4f, O
   {0x1e, 0x11, 0x11, 0x1e, 0x10, 0x10, 0x10,}   // 0x50, P
   {0x0e, 0x11, 0x11, 0x11, 0x15, 0x12, 0x0d,}   // 0x51, Q
   {0x1e, 0x11, 0x11, 0x1e, 0x14, 0x12, 0x11,}   // 0x52, R
   {0x0e, 0x11, 0x10, 0x0e, 0x01, 0x11, 0x0e,}   // 0x53, S
   {0x1f, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04,}   // 0x54, T
   {0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x0e,}   // 0x55, U
   {0x11, 0x11, 0x11, 0x11, 0x11, 0x0a, 0x04,}   // 0x56, V
   {0x11, 0x11, 0x11, 0x15, 0x15, 0x1b, 0x11,}   // 0x57, W
   {0x11, 0x11, 0x0a, 0x04, 0x0a, 0x11, 0x11,}   // 0x58, X
   {0x11, 0x11, 0x0a, 0x04, 0x04, 0x04, 0x04,}   // 0x59, Y
   {0x1f, 0x01, 0x02, 0x04, 0x08, 0x10, 0x1f,}   // 0x5a, Z
   {0x0e, 0x08, 0x08, 0x08, 0x08, 0x08, 0x0e,}   // 0x5b, [
   {0x10, 0x10, 0x08, 0x04, 0x02, 0x01, 0x01,}   // 0x5c, \
   {0x0e, 0x02, 0x02, 0x02, 0x02, 0x02, 0x0e,}   // 0x5d, ]
   {0x04, 0x0a, 0x11, 0x00, 0x00, 0x00, 0x00,}   // 0x5e, ^
   {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f,}   // 0x5f, _
const unsigned char Font3[32][7] = {
   {0x04, 0x04, 0x02, 0x00, 0x00, 0x00, 0x00,}   // 0x60, `
   {0x00, 0x0e, 0x01, 0x0d, 0x13, 0x13, 0x0d,}   // 0x61, a
   {0x10, 0x10, 0x10, 0x1c, 0x12, 0x12, 0x1c,}   // 0x62, b
   {0x00, 0x00, 0x00, 0x0e, 0x10, 0x10, 0x0e,}   // 0x63, c
   {0x01, 0x01, 0x01, 0x07, 0x09, 0x09, 0x07,}   // 0x64, d
   {0x00, 0x00, 0x0e, 0x11, 0x1f, 0x10, 0x0f,}   // 0x65, e
   {0x06, 0x09, 0x08, 0x1c, 0x08, 0x08, 0x08,}   // 0x66, f
   {0x0e, 0x11, 0x13, 0x0d, 0x01, 0x01, 0x0e,}   // 0x67, g
   {0x10, 0x10, 0x10, 0x16, 0x19, 0x11, 0x11,}   // 0x68, h
   {0x00, 0x04, 0x00, 0x0c, 0x04, 0x04, 0x0e,}   // 0x69, i
   {0x02, 0x00, 0x06, 0x02, 0x02, 0x12, 0x0c,}   // 0x6a, j
   {0x10, 0x10, 0x12, 0x14, 0x18, 0x14, 0x12,}   // 0x6b, k
   {0x0c, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04,}   // 0x6c, l
   {0x00, 0x00, 0x0a, 0x15, 0x15, 0x11, 0x11,}   // 0x6d, m
   {0x00, 0x00, 0x16, 0x19, 0x11, 0x11, 0x11,}   // 0x6e, n
   {0x00, 0x00, 0x0e, 0x11, 0x11, 0x11, 0x0e,}   // 0x6f, o
   {0x00, 0x1c, 0x12, 0x12, 0x1c, 0x10, 0x10,}   // 0x70, p
   {0x00, 0x07, 0x09, 0x09, 0x07, 0x01, 0x01,}   // 0x71, q
   {0x00, 0x00, 0x16, 0x19, 0x10, 0x10, 0x10,}   // 0x72, r
   {0x00, 0x00, 0x0f, 0x10, 0x0e, 0x01, 0x1e,}   // 0x73, s
   {0x08, 0x08, 0x1c, 0x08, 0x08, 0x09, 0x06,}   // 0x74, t
   {0x00, 0x00, 0x11, 0x11, 0x11, 0x13, 0x0d,}   // 0x75, u
   {0x00, 0x00, 0x11, 0x11, 0x11, 0x0a, 0x04,}   // 0x76, v
   {0x00, 0x00, 0x11, 0x11, 0x15, 0x15, 0x0a,}   // 0x77, w
   {0x00, 0x00, 0x11, 0x0a, 0x04, 0x0a, 0x11,}   // 0x78, x
   {0x00, 0x11, 0x11, 0x0f, 0x01, 0x11, 0x0e,}   // 0x79, y
   {0x00, 0x00, 0x1f, 0x02, 0x04, 0x08, 0x1f,}   // 0x7a, z
   {0x06, 0x08, 0x08, 0x10, 0x08, 0x08, 0x06,}   // 0x7b, {
   {0x04, 0x04, 0x04, 0x00, 0x04, 0x04, 0x04,}   // 0x7c, |
   {0x0c, 0x02, 0x02, 0x01, 0x02, 0x02, 0x0c,}   // 0x7d, }
   {0x08, 0x15, 0x02, 0x00, 0x00, 0x00, 0x00,}   // 0x7e, ~
   {0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f,}   // 0x7f, DEL
and saved as font.C..........
then called it by...
#include <htc.h>
__CONFIG(LVP_OFF & BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_XT);
#define _XTAL_FREQ 4000000\
#define DAD PORTB
#define RST RD7
#define CLK RD4
#define DATA RD5
#define D 1
external const unsigned char Font[][];
main (){
TRISB=0B00000000;
TRISD=0B00000000;
unsigned char x;
x = Font1[3];
DAD=x;
showing error...
Make: The target "C:\Documents and Settings\WETA DIGITAL\My Documents\map\flash.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 "C:\Documents and Settings\WETA DIGITAL\My Documents\map\flash.C" -q --chip=16F877A -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Warning [374] C:\Documents and Settings\WETA DIGITAL\My Documents\map\flash.C; 10.10 missing basic type; int assumed
Error [314] C:\Documents and Settings\WETA DIGITAL\My Documents\map\flash.C; 10.10 ";" expected
Error [192] C:\Documents and Settings\WETA DIGITAL\My Documents\map\flash.C; 16.5 undefined identifier "Font1"
Error [981] C:\Documents and Settings\WETA DIGITAL\My Documents\map\flash.C; 16.13 pointer required
Error [192] C:\Documents and Settings\WETA DIGITAL\My Documents\map\flash.C; 17.1 undefined identifier "DAD"
********** Build failed! **********
HI again,
Its working now, I notice that fboth file should be included to source file!!!
The code is working fine.....
but i have seen your tutorial 13, you were using string, please tell how to add string while selecting its array row column automatically..??
#include <htc.h>
#define DAD PORTB
#define RST RD7
#define CLK RD4
#define DATA RD5
#define D 1
extern const unsigned char Font2[32][7];
int data(int a);
main (){
TRISD=0B00000000;
TRISB=0B00000000;
while(1){
DAD=0X00;
int a;
for(int i=1;i<32;i++){
for (int k=0;k<100;k++){
int o=0;
a=Font2[i][o];
data(a);
DAD=0X80;
__delay_ms(D);
o++;
a=Font2[i][o];
data(a);
DAD=0X40;
__delay_ms(D);
o++;
a=Font2[i][o];
data(a);
DAD=0X20;
__delay_ms(D);
o++;
a=Font2[i][o];
data(a);
DAD=0X10;
__delay_ms(D);
o++;
a=Font2[i][o];
data(a);
DAD=0X08;
__delay_ms(D);
o++;
a=Font2[i][o];
data(a);
DAD=0X04;
__delay_ms(D);
o++;
a=Font2[i][o];
data(a);
DAD=0X02;
__delay_ms(D);
o++;
int data(int a)
RST=0;
RST=1;
DAD=0X00;
for (int k=0; k<8;k++) {
CLK = 0;
    if ((a & 0x01)==1) DATA = 1;
    else DATA =0;
    CLK =1;
    a >>=1;
Excellent.... One thing.. You have 3 arrays... So you have to put 3 declarations in the main C file
external const unsigned char Font1[][];
external const unsigned char Font2[][];
external const unsigned char Font3[][];
I would just do this..
const unsigned char Font[] = {
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,   // 0x20, Space
   0x04, 0x04, 0x04, 0x04, 0x04, 0x00, 0x04,   // 0x21, !
   0x09, 0x09, 0x12, 0x00, 0x00, 0x00, 0x00,   // 0x22, "
   0x0a, 0x0a, 0x1f, 0x0a, 0x1f, 0x0a, 0x0a,   // 0x23, #
   0x04, 0x0f, 0x14, 0x0e, 0x05, 0x1e, 0x04,   // 0x24, $
   0x19, 0x19, 0x02, 0x04, 0x08, 0x13, 0x13,   // 0x25, %
   0x04, 0x0a, 0x0a, 0x0a, 0x15, 0x12, 0x0d,   // 0x26, &
   0x04, 0x04, 0x08, 0x00, 0x00, 0x00, 0x00,   // 0x27, '
   0x02, 0x04, 0x08, 0x08, 0x08, 0x04, 0x02,   // 0x28, (
   0x08, 0x04, 0x02, 0x02, 0x02, 0x04, 0x08,   // 0x29, )
   0x04, 0x15, 0x0e, 0x1f, 0x0e, 0x15, 0x04,   // 0x2a, *
   0x00, 0x04, 0x04, 0x1f, 0x04, 0x04, 0x00,   // 0x2b, +
   0x00, 0x00, 0x00, 0x00, 0x04, 0x04, 0x08,   // 0x2c, ,
   0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00,   // 0x2d, -
   0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x0c,   // 0x2e, .
   0x01, 0x01, 0x02, 0x04, 0x08, 0x10, 0x10,   // 0x2f, /
   0x0e, 0x11, 0x13, 0x15, 0x19, 0x11, 0x0e,   // 0x30, 0
   0x04, 0x0c, 0x04, 0x04, 0x04, 0x04, 0x0e,   // 0x31, 1
   0x0e, 0x11, 0x01, 0x02, 0x04, 0x08, 0x1f,   // 0x32, 2
   0x0e, 0x11, 0x01, 0x06, 0x01, 0x11, 0x0e,   // 0x33, 3
   0x02, 0x06, 0x0a, 0x12, 0x1f, 0x02, 0x02,   // 0x34, 4
   0x1f, 0x10, 0x1e, 0x01, 0x01, 0x11, 0x0e,   // 0x35, 5
   0x06, 0x08, 0x10, 0x1e, 0x11, 0x11, 0x0e,   // 0x36, 6
   0x1f, 0x01, 0x02, 0x04, 0x08, 0x08, 0x08,   // 0x37, 7
   0x0e, 0x11, 0x11, 0x0e, 0x11, 0x11, 0x0e,   // 0x38, 8
   0x0e, 0x11, 0x11, 0x0f, 0x01, 0x02, 0x0c,  // 0x39, 9
   0x00, 0x0c, 0x0c, 0x00, 0x0c, 0x0c, 0x00,   // 0x3a, :
   0x00, 0x0c, 0x0c, 0x00, 0x0c, 0x04, 0x08,   // 0x3b, ;
   0x02, 0x04, 0x08, 0x10, 0x08, 0x04, 0x02,   // 0x3c, <
   0x00, 0x00, 0x1f, 0x00, 0x1f, 0x00, 0x00,   // 0x3d, =
   0x08, 0x04, 0x02, 0x01, 0x02, 0x04, 0x08,   // 0x3e, >
   0x0e, 0x11, 0x01, 0x02, 0x04, 0x00, 0x04,   // 0x3f, ?
   0x0e, 0x11, 0x17, 0x15, 0x17, 0x10, 0x0f,   // 0x40, @
   0x04, 0x0a, 0x11, 0x11, 0x1f, 0x11, 0x11,   // 0x41, A
   0x1e, 0x11, 0x11, 0x1e, 0x11, 0x11, 0x1e,   // 0x42, B
   0x0e, 0x11, 0x10, 0x10, 0x10, 0x11, 0x0e,   // 0x43, C
   0x1e, 0x09, 0x09, 0x09, 0x09, 0x09, 0x1e,   // 0x44, D
   0x1f, 0x10, 0x10, 0x1c, 0x10, 0x10, 0x1f,   // 0x45, E
   0x1f, 0x10, 0x10, 0x1f, 0x10, 0x10, 0x10,   // 0x46, F
   0x0e, 0x11, 0x10, 0x10, 0x13, 0x11, 0x0f,   // 0x37, G
   0x11, 0x11, 0x11, 0x1f, 0x11, 0x11, 0x11,   // 0x48, H
   0x0e, 0x04, 0x04, 0x04, 0x04, 0x04, 0x0e,   // 0x49, I
   0x1f, 0x02, 0x02, 0x02, 0x02, 0x12, 0x0c,   // 0x4a, J
   0x11, 0x12, 0x14, 0x18, 0x14, 0x12, 0x11,   // 0x4b, K
   0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x1f,   // 0x4c, L
   0x11, 0x1b, 0x15, 0x11, 0x11, 0x11, 0x11,   // 0x4d, M
   0x11, 0x11, 0x19, 0x15, 0x13, 0x11, 0x11,   // 0x4e, N
   0x0e, 0x11, 0x11, 0x11, 0x11, 0x11, 0x0e,   // 0x4f, O
   0x1e, 0x11, 0x11, 0x1e, 0x10, 0x10, 0x10,   // 0x50, P
   0x0e, 0x11, 0x11, 0x11, 0x15, 0x12, 0x0d,   // 0x51, Q
   0x1e, 0x11, 0x11, 0x1e, 0x14, 0x12, 0x11,   // 0x52, R
   0x0e, 0x11, 0x10, 0x0e, 0x01, 0x11, 0x0e,   // 0x53, S
   0x1f, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04,   // 0x54, T
   0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x0e,   // 0x55, U
   0x11, 0x11, 0x11, 0x11, 0x11, 0x0a, 0x04,   // 0x56, V
   0x11, 0x11, 0x11, 0x15, 0x15, 0x1b, 0x11,   // 0x57, W
   0x11, 0x11, 0x0a, 0x04, 0x0a, 0x11, 0x11,   // 0x58, X
   0x11, 0x11, 0x0a, 0x04, 0x04, 0x04, 0x04,   // 0x59, Y
   0x1f, 0x01, 0x02, 0x04, 0x08, 0x10, 0x1f,   // 0x5a, Z
   0x0e, 0x08, 0x08, 0x08, 0x08, 0x08, 0x0e,   // 0x5b, [
   0x10, 0x10, 0x08, 0x04, 0x02, 0x01, 0x01,   // 0x5c, \
   0x0e, 0x02, 0x02, 0x02, 0x02, 0x02, 0x0e,   // 0x5d, ]
   0x04, 0x0a, 0x11, 0x00, 0x00, 0x00, 0x00,   // 0x5e, ^
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f,   // 0x5f, _
   0x04, 0x04, 0x02, 0x00, 0x00, 0x00, 0x00,   // 0x60, `
   0x00, 0x0e, 0x01, 0x0d, 0x13, 0x13, 0x0d,   // 0x61, a
   0x10, 0x10, 0x10, 0x1c, 0x12, 0x12, 0x1c,   // 0x62, b
   0x00, 0x00, 0x00, 0x0e, 0x10, 0x10, 0x0e,   // 0x63, c
   0x01, 0x01, 0x01, 0x07, 0x09, 0x09, 0x07,   // 0x64, d
   0x00, 0x00, 0x0e, 0x11, 0x1f, 0x10, 0x0f,   // 0x65, e
   0x06, 0x09, 0x08, 0x1c, 0x08, 0x08, 0x08,   // 0x66, f
   0x0e, 0x11, 0x13, 0x0d, 0x01, 0x01, 0x0e,   // 0x67, g
   0x10, 0x10, 0x10, 0x16, 0x19, 0x11, 0x11,   // 0x68, h
   0x00, 0x04, 0x00, 0x0c, 0x04, 0x04, 0x0e,   // 0x69, i
   0x02, 0x00, 0x06, 0x02, 0x02, 0x12, 0x0c,   // 0x6a, j
   0x10, 0x10, 0x12, 0x14, 0x18, 0x14, 0x12,   // 0x6b, k
   0x0c, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04,   // 0x6c, l
   0x00, 0x00, 0x0a, 0x15, 0x15, 0x11, 0x11,   // 0x6d, m
   0x00, 0x00, 0x16, 0x19, 0x11, 0x11, 0x11,   // 0x6e, n
   0x00, 0x00, 0x0e, 0x11, 0x11, 0x11, 0x0e,   // 0x6f, o
   0x00, 0x1c, 0x12, 0x12, 0x1c, 0x10, 0x10,   // 0x70, p
   0x00, 0x07, 0x09, 0x09, 0x07, 0x01, 0x01,   // 0x71, q
   0x00, 0x00, 0x16, 0x19, 0x10, 0x10, 0x10,   // 0x72, r
   0x00, 0x00, 0x0f, 0x10, 0x0e, 0x01, 0x1e,   // 0x73, s
   0x08, 0x08, 0x1c, 0x08, 0x08, 0x09, 0x06,   // 0x74, t
   0x00, 0x00, 0x11, 0x11, 0x11, 0x13, 0x0d,   // 0x75, u
   0x00, 0x00, 0x11, 0x11, 0x11, 0x0a, 0x04,   // 0x76, v
   0x00, 0x00, 0x11, 0x11, 0x15, 0x15, 0x0a,   // 0x77, w
   0x00, 0x00, 0x11, 0x0a, 0x04, 0x0a, 0x11,   // 0x78, x
   0x00, 0x11, 0x11, 0x0f, 0x01, 0x11, 0x0e,   // 0x79, y
   0x00, 0x00, 0x1f, 0x02, 0x04, 0x08, 0x1f,   // 0x7a, z
   0x06, 0x08, 0x08, 0x10, 0x08, 0x08, 0x06,   // 0x7b, {
   0x04, 0x04, 0x04, 0x00, 0x04, 0x04, 0x04,   // 0x7c, |
   0x0c, 0x02, 0x02, 0x01, 0x02, 0x02, 0x0c,   // 0x7d, }
   0x08, 0x15, 0x02, 0x00, 0x00, 0x00, 0x00,   // 0x7e, ~
   0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f}   // 0x7f, DEL
You only need a 1d array each element can be accessed by ((ASCII CODE - 0x20) * 7 ) As each char is 7 bits long...
