How to use ports in a loop
osmanandac
I want to make like a following code
// the port definitons
RA3=my_ports(0)
RB2=my_ports(1)
RA1=my_ports(2)
RB7=my_ports(3)
RB0=my_ports(4)
Rxx=my_ports(x)
//then use in loop
for(i=0;i<10;i++)
my_ports(i)=1;
my_ports(i)=0;
I don't understand what you are trying to do. If you post a reply please include which chip and compiler you are using.
If that is what he is asking then, in BoostC, you can do,
volatile int Ports @PORTA;
int PortBits[16]={
    0x8000,0x4000,0x2000,0x1000,
    0x0800,0x0400,0x0200,0x0100,
    0x0080,0x0040,0x0020,0x0010,
    0x0008,0x0004,0x0002,0x0001
void SetPort(char index){
    Ports=PortBits[index];
With the above, SetPort(0) will set bit 7 of PortB. Swapping the values in the table will change the order.
Yes this is my solution
int PortBits[16]={
Thank you Mike for reply, i am using 16F877 and 16F628.
You replied solution for only one port. Can i define PORTA, PORTB, PORTC ports are together in ports structure?
