I feel silly, but....
Vizier87
Active Member
Hi guys,
Sorry to ask such a simple question.
I'm using MikroC now (since I've been using Assembly for simple tasks) and couldn't get my PIC18F4455 to turn on an LED. I read the initialization on the PORTB part on the datasheet, which states:
CLRF PORTB ; Initialize PORTB by
; clearing output
; data latches
CLRF LATB ; Alternate method
; to clear output
; data latches
MOVLW 0Eh ; Set RB<4:0> as
MOVWF ADCON1 ; digital I/O pins
; (required if config bit
; PBADEN is set)
MOVLW 0CFh ; Value used to
; initialize data
; direction
MOVWF TRISB ; Set RB<3:0> as inputs
; RB<5:4> as outputs
; RB<7:6> as inputs
Now here's my C code, trying to turn on all the PORTB pins,
C:
void main() {
     PORTB=0X00;
     LATB=0X00;
     ADCON1=0X0F;
PORTB= 0b11111111;
while (1){
Sometimes the PIC turned on well, but then it turns off again when I interrupt its supply i.e it doesn't seem to return to its original state. I suspect it might have to do with other configurations, but I suppose MikroC covers such details when I used the Project Wizard.
Any help would be highly appreciated.
Vizier87
okay, so I tried it like this:
C:
void main() {
     ANSELH=0X00
     PORTB=0X00;
     LATB=0X00;
     ADCON1=0X0F;
     TRISB=0X00;
PORTB= 0b11111111;
while (1){
But still no avail.
It sounds like you are getting a brown out. Try turning on the brownout reset in the config.
Hi Mike, I'm using MikroC and that's where I'm a bit at loss. During the days I'm using templates of ASM, the config part is shown properly.
However, how do I go about configuring the Config part through MikroC? Is it done as part of the code itself?
Thanks.
Vizier87
Thanks.
Vizier87
I'm afraid I don't use MikroC so not sure how you set the config. Guess you'll have to check the manual.
You set the config under the top menu; Project -> Edit_Project
then check the config boxes as desired.
You should have a good read through the PIC datasheet under "Special features of the CPU" chapter which described the effect of all the config options. :)
hi Mr RB,
yeah thanks for your info. I'll try to get a look into it. :)
Hi guys,
Still no avail. I changed the Brown Out to "Disabled in Hardware, SBOREN Disabled". Anything else which needs to be changed?BTW, my crystal osc is 20 MHz, just to inform you guys.
Here's a screenshot:
Vizier87
Also, if you have a 20MHz crystal then the top box (prescaler) needs to be 5.
Set the "Brown Out Detect" to on.
Hi, thanks for the input. The Brownout options are:
Which one should it be?
Also here's my code, please check it out:
C:
void main() {
PORTB=0x00;
LATB=0X00;
ADCON1=0X0F;
TRISB=0X00;
PORTB= 0b11111111;
while (1){
Also, how about the CPU system clock Post Scaler?
thanks.
With a 20MHz crystal you need the prescaler set to 5 so the PLL gets 4MHz. The output will be 96MHz and so you need to divide it by something like 4 to get a usable 24MHz. So postscaler = 4. The oscillator type should be HSPLL (High speed - pll enabled).
The brownout reset should be enabled in hardware.
