Yes it does make an ASM file.
I think it's probably hardware related, ie xtal not plugged in, LEDs turned off, MCLR pin not handled correctly etc.
Your oscillator frequency should be 48mhz not 20mhz
You also need to set ADCON1 right.
void main() {
ADCON0 = 0B00111100;
ADCON1 = 0B00001111;
LATB = 0;
TRISB = 0B00000000;
LATB = 0B11111111;
while(1);
Hi, thanks for the input. I put the value of ADCON1=0X0F, I suppose that should set all of the pins as output, yeah?
Also, can you explain why I need it to be 48 MHz? I'm not using it for USB purposes at the moment.
bit 1 PBADEN: PORTB A/D Enable bit
(Affects ADCON1 Reset state. ADCON1 controls PORTB<4:0> pin configuration.)
1 = PORTB<4:0> pins are configured as analog input channels on Reset
0 = PORTB<4:0> pins are configured as digital I/O on Reset
I posted why I don't no where it went but any way Your using a 20 mhz crystal you divided it by 5 that gives the 4 mhz that's scaled to 96 then divided by 2
which is 48 mhz it's not 20mhz If you want 20 set the FOSC to HS only
One more thing you can turn off the A/D on PORTB in the configure to
Hi Mike, yeah, the one which worked is according to the settings you suggested. Thanks.I'm sure I said to set the postscaler to divide by 4 which would give you 24MHz.
I went back and looked your using a divide by 4 which gives a 24Mhz like Mike said But in your pic you show 20 which is wrong it will make thing like uart not work and things with timing
The reason I said divide by 2 is that's the default setting for the PIC18F2455/2550/4455/4550 in MikroC sorry about that
I been using the start usb which has the 18f2550 on it which uses the same setting
void main() {
CMCON=0B00000111;
UCON=0B00010000;
ADCON0=0B00111100;
ADCON1=0B00001111;
CVRCON=0;
LATA=0B000000;
TRISA=0B000000;
PORTA=0B111111;
while(1); }
Hi Atomsoft, thanks for the feedback.
What's the reason behind the orientation anyway?
Seems you cleared LATB first and then put it all on HIGH.
Vizier87
