I have received an example schematic of how an audio preamplifier should look like. Based on that and a set of data(input voltage(7V), input resistance(60 ohms), output resistance(8 ohms) and amplification(2.1) ) I have to design my own schematic(which shouldn't be a lot different at the end of the day), but I don't quite understand how to do it.
Note: this is the 1st time I am designing a circuit, so I really don't know much about it.
My questions are:
*First, why is an AC power supply used as an input for the circuit?
*Which exactly are the values of the input and output voltage in this image(so I can calculate the amplification); The reason I am asking this is because I see those "0V" values
*Is there any simple way to explain how changing the circuit(adding resistors, changing a resistor to a very high value etc.) influences the circuit?
I am assuming the 81.54mV is the ouput voltage(still need an answer). All my attempts to modify the circuit (using my parameters and other transistor(we have to use a different one from BC109C) ) led to attenuation instead of amplification.
https://i.postimg.cc/hvD9zrQz/Untitled.png
My questions are:
