circuitman1989
Hi, I need a circuit to convert 12vdc at 15amps into 6vdc at 12-15amps. the reason I need the circuit is I went to a yard sale the other day, the lady's husband (who had worked on engines) had passed away and she was selling a lot of NOS engine parts... I found a brand new ignition coil still in the box that was marked $.50us so I bought it for my lawn mower engine that had mechanical points but the PO had installed an electronic maginito onto the engine and now the maginito is failing. Well when I got home I noticed the coil said it was for a 6 volt system and the original system was 12 volts
and I can't get a 6 volt starter for a 1977 8hp briggs and stratton engine. so I need a circuit to make 12vdc into 6vdc for the ignition coil but keep the rest of the system at 12vdc and have a common 12vdc negitive ground.
thanks in advance,
John
thanks in advance,
John
