i need Audio level meter layout
marvel2025
hi all
plz i need the layout of Audio level meter ((very simple ct.)) that i can make it on the PCB
thanks
Are you sure you are using a 4017?
Usually a 4017 has only one clock input, a clock inhibit input and a reset input.
The 4017 will advance count with each amplifier output signal strong enough to clock the chip, hence it won't be a an audio level indicator.
I suggest to take a look at the LM3915, a logarithmic version of the LM3914.
Boncuk
This is called a data sheet. National Semiconductor provides these data sheets for their products.
  • LM3915.pdf
