I need to trick a fluid sensor to return a full signal
hhoarder
My car has an AdBlue fluid sensor that isn't working properly. It's an ultrasonic sensor and the car is reading 0mm of fluid from the sensor (out of maximum 245mm), despite the tank being full. A replacement part is only deliverable in July or so, which basically turns my car into a brick until then. My only hope is somehow tricking the sensor/car into reading the tank as being full.
I don't know exactly what kind of output the sensor is producing, but looking online at various ultrasonic sensors, they all seem to output 4-20mA.
Here is the wiring diagram for the sensor:
As you can see, the sensor uses 3 wires - positive, negative and signal.
My question is, how would I go about using the signal wire to send back "tank full" signal to the car?
Any help or tips are much appreciated, thank you!
Edit: after doing some more research, I've found that the module in question is Bosch Denoxtronic 5.
I recall using, just for testing 4-20 chanels of an alarms pannel, a portable variable constant current source.
But, just for testing.
A LINear signal is just the average DC voltage of any PWM duty cycle with a potential range of 0.5 to 4.5V for 10 % to 90% PWM.
Measure what you have then try something else.
My oops
Thank you for your comment. Any tips on how I would go about producing a LIN signal?
With any signal, you need to find out what needs to be sent first.
One way would be to record a working sensor. It is possible that a sensor that is stuck at 0% would give you a clue as allow you to guess what needs to be sent.
In LIN, the frame ID is always sent by the master, and it's likely that the sensor is the slave, so it might be possible to look at what frames IDs are being sent by the master and to guess the frame content.
A microcontroller / arduino / Raspberry Pi or similar would be needed if it is a LIN system.
I'm afraid I don't have any other sensor to try. However, I do have a few Raspberries and one older Arduino. I've already found a library that can sniff LIN messages, so if the sensor is indeed using LIN, I should hopefully be able to figure out the protocol and then send my own messages.
Thank you very much for pointing me in this direction!
I've raised the car again and measured some stuff, but I've gotten unexpected results.
Measuring between + and - gives 12V as expected. However, it's showing 7.2V between + and signal wire. Am I correct in assuming that the car is sending a 7.2V to the sensor? Would that mean it's trying to initiate some sort of start-up protocol?
Edit: the values above were measured inside the plug that's going from the car to the sensor. I've disconnected the plug and then measured the pins inside, the sensor was never involved.
I suspect that the signal from the sensor is just a voltage, so more voltage represents more fluid.
Can you measure the voltage from the signal wire to ground. It should be 12 - 7.2 = 4.8 V but it's worth checking.
Can you also measure the voltages with the sensor disconnected?
What does the car say that the fluid level is when the sensor is disconnected?
I'm sorry, I should have been more specific - I have disconnected the plug from the car to the sensor and I've measured the voltages inside the plug itself. The sensor was completely disconnected during this time. So the plug going into the sensor had 7.2V between + and SIG.
The raw fluid value is still showing as 0, just as it was when the sensor was actually connected.
