I2C display doesn't give an acknowledge
3Dfx
Hello everyone!
I've got a NHD-C160100DiZ-FSW-FBW display and a Simcom sim5360 module. The display is connected correctly - that is for sure. I tried to get connected using a datasheet example (using Lua language), but the display doesn't get ACK-bit - the SDA line is staying HIGH.
Here is a modified code I am using now but there is still no ACK bit. I would greatly appreciate any help from you.
function I2C_out(j) --//I2C Output
    print("~~I2C output '",string.format("0x%X",j),"':\r\n")
    local d, n;
    d=j;
    n=0;
    vmsleep(delay);
    print("1. Sending 8 bits (n = [0,7])\r\n")
    for n = 0,7 do --//send 8 bits
        print("1.",n+1,".1) n = ", n, ", d = ",d, ", d and 0x80 = ",bit.band(d,0x80),". ");
        if(bit.band(d,0x80) == 0x80) then --//get only the MSB
            setHIGH(SDA);--SDA=1; --//If it is 1 then SDA=1
            print("SDA to 1: SDA == ", gpio.getv(SDA),"\r\n");
        else
            setLOW(SDA);--SDA=0; --//If 0 then SDA=0
            print("SDA to 0: SDA == ", gpio.getv(SDA),"\r\n");
        end
        vmsleep(delay);
        print("1.",n+1,".2) SCL clocks\r\n");
        print("SСL to 0: ")
        setLOW(SCL);--SCL = 0;
        print("SCL == ",gpio.getv(SCL),"\r\n")
        vmsleep(delay);
        print("SСL to 1: ")
        setHIGH(SCL);--SCL = 1; --//clock in data
        vmsleep(2*delay);
        d = bit.lshift(d,1);--d=(d<<1); --//shift data byte left
        print("SСL to 0: ")
        vmsleep(delay);
    end;
    print("\r\n2.\r\n")
    print("SDA to 1: ")
    setHIGH(SDA);--SDA = 1;
    print("SDA == ",gpio.getv(SDA),"\r\n")
    vmsleep(2*delay);
    print("SСL to 1: ")
    vmsleep(2*delay);
    print("SСL to 0: ")
    vmsleep(delay);
    pinToIN(SDA);
    print("3. Wait until ACK:\r\n")
    while(gpio.getv(SDA)==1) do --//wait here until ACK
        print("SСL to 0: ")
        vmsleep(delay);
        print("SСL to 1: ")
        vmsleep(delay);
        print("NACK (Sending '", string.format("0x%X",j)," (gpio.getv(SDA) == ",gpio.getv(SDA),"')\r\n");
    end;
    print("!!!!!!!!!!!ACK!!!!!!!!!!!!\r\n");
    pinToOUT(SDA);
    vmsleep(delay);
    vmsleep(delay);
end;
function I2C_Start(void)
    print("~~Start:\r\n")
    print("SСL to 1: ");
    setHIGH(SCL)--SCL = 1;
    print("SCL == ",gpio.getv(SCL),"\r\n");
    vmsleep(10)
    print("SDA to 1: ")
    vmsleep(10)
    print("SDA to 0: ")
    setLOW(SDA);--SDA = 0;
    vmsleep(10)
    print("SСL to 0: ")
    vmsleep(10)
    print("~~(endstart)\r\n");
end
function I2C_Stop(void)
    print("~~Stop:\r\n")
    print("SDA to 0: ")
    vmsleep(10)
    print("SСL to 0: ")
    vmsleep(10)
    vmsleep(10)
    print("SDA to 1: ")
    vmsleep(10)
    print("~~(endstop)\r\n");
end
function Show(text)
    local n,i;
    local page=0xB0;  --//first page
    for i=0, 13 do --//100 pixels = 12.5 pages
        I2C_Start();
        I2C_out(Slave);
        I2C_out(Comsend);
        I2C_out(page);
        I2C_out(0x10); --//column address Y9:Y6
        I2C_out(0x01); --//column address Y5:Y2
        I2C_Stop();
        I2C_Start();
        I2C_out(Slave);
        I2C_out(Datasend);
        for n=0, 160 do
            I2C_out(text);  --//send data 4 times for grayscaling
            I2C_out(text);
            I2C_out(text);
            I2C_out(text);
            text = text+1;  --//point to next byte of data
            vmsleep(10);
        end
        I2C_Stop();
        page = page+1;  --//move to next page
    end
end
--* LCD Initialization *
function init_LCD()
    I2C_Start();
    I2C_out(Slave);
    for n = 1, #initTable do
        I2C_out(initTable[n]);
    end
    I2C_Stop();
end
--* MAIN *
Slave = 0x3F; --//slave address
--Comsend = 0x00;
--Datasend = 0x40;
initTable = {
    0x00,    --Comsend
    -- Select partial display line (p. 56)
    -- Sets the ratio within range of 16 to 128 (ICON disabled) or 17 to 129 (ICON enabled)
    -- to realize partial display by using the 2-byte instruction
    0x48,    -- 1-st
    0x64,    -- 2-nd : 1/100 duty
    -- ADC select (p. 62)
    -- Changes the relationship between RAM column address and segment driver.
    -- The direction of segment driver output pins could be reversed by software.
    -- This makes IC layout flexible in LCD module assembly.
    0xA0,    -- ADC = 0: normal direction (SEG0 -> SEG127)
    -- SHL select (p. 61)
    -- COM output scanning direction is selected by this instruction which determines the LCD driver output status.
    0xC8,    -- SHL = 1: reverse direction (COM127 -> COM0)
    -- Set Initial COM0 Register (p. 55)
    -- Sets the initial row (COM) of the LCD panel using the 2-byte instruction.
    -- By using this instruction, it is possible to realize the window moving without the change of display data.
    0x44,    -- 1-st
    0x00,    -- 2-nd scan from COM0
    --    Oscillator ON Start (p. 62)
    0xAB,    -- This instruction enables the built-in oscillator circuit
    -- Select Regulator Resistor (p. 60)
    -- Selects resistance ratio of the internal resistor used in the internal voltage regulator.
    -- See voltage regulator section in power supply circuit
    0x26, -- 1+ (Rb / Ra) = 6.5
    -- Set Electronic Volume Register (p. 60)
    -- Consist of 2-byte Instructions
    -- The 1st instruction set Reference Voltage mode,
    -- the 2nd one updates the contents of reference voltage register.
    -- After second instruction, Reference Voltage mode is released.
    0x81,    -- 1-st *****
    0x18,    -- 2-nd
    -- 0x1C, -- 2-nd
    -- Select LCD bias (p. 60)
    -- Selects LCD bias ratio of the voltage required for driving the LCD.
    0x57,    -- 1/12
    -- 0x56, -- 1/11 ****
    -- Select DC-DC Step-up (p. 59)
    -- Selects one of 4 DC-DC step-up to reduce the power consumption by this instruction.
    -- It is very useful to realize the partial display function.
    0x64,    -- 3x times boosting circuit
    0xE3,    -- NOP (p. 64)
    -- Power control (p. 58)
    0x2C,    --    Internal voltage converter circuit is ON
    0x66,    -- 5x times boosting circuit
    0x2E,    -- Internal voltage converter circuit is ON
            -- Internal voltage regulator circuit is ON
    0x2F,    -- Internal voltage converter circuit is ON
            -- Internal voltage follower circuit is ON
    -- Set Bias Power Save Mode (p. 58)
    -- This command is for saving the IC current consumption by Bias Power Saving
    -- After this Instruction is set, Bias function is also working
    0xF3,    -- 1-st
    0x00,    -- 2-nd
    -- Set FRC & PWM mode (p. 65)
    0x96,    -- 3FRC
            -- 60PWM
    -- Set Mode Register (p. 49)
    -- 2-byte instruction to set Mode (EXT) and FR (Frame frequency control), BE (Booster efficiency control).
    -- Booster Efficiency
    -- The ST7528 incorporates software configurable Booster Efficiency Command.
    -- It could be used with Voltage multiplier to get the suitable Vout and Power consumption.
    -- Default setting is Level 2
    0x38,    -- 1-st
    0x75,    -- 2-nd
            -- FR frequency = 70 Hz ±20%
            -- Booster Efficiency Level 2
            -- The Instruction of EXT=1 Mode is available
    0x95,    -- 3FRC
            -- 45PWM
    -- 0x97, ****
    -- 16-level (White Mode ~ Dark Mode) Gray Scale Display with PWM and FRC Methods
    -- (p. 1)
--start 16-level grayscale settings
    -- Set Gray Scale Mode & Register (p. 65)
    -- Consists of 2 bytes instruction.
    -- The first byte sets grayscale mode and the second byte updates the contents
    -- of gray scale register without issuing any other instruction.
    0x80, -- Set white mode and 1st frame
    0x00, -- set pulse width
    0x81, -- Set white mode and 2nd frame
    0x82, -- Set white mode and 3rd frame
    0x83, -- Set white mode and 4th frame
    0x84,
    0x06,
    0x85,
    0x06,
    0x86,
    0x06,
    0x87,
    0x06,
    0x88,
    0x0B,
    0x89,
    0x0B,
    0x8A,
    0x0B,
    0x8B,
    0x0B,
    0x8C,
    0x10,
    0x8D,
    0x10,
    0x8E,
    0x10,
    0x8F,
    0x10,
    0x90,
    0x15,
    0x91,
    0x15,
    0x92,
    0x15,
    0x93,
    0x15,
    0x94,
    0x1A,
    0x95,
    0x1A,
    0x96,
    0x1A,
    0x97,
    0x1A,
    0x98,
    0x1E,
    0x99,
    0x1E,
    0x9A,
    0x1E,
    0x9B,
    0x1E,
    0x9C,
    0x23,
    0x9D,
    0x23,
    0x9E,
    0x23,
    0x9F,
    0x23,
    0xA0,
    0x27,
    0xA1,
    0x27,
    0xA2,
    0x27,
    0xA3,
    0x27,
    0xA4,
    0x2B,
    0xA5,
    0x2B,
    0xA6,
    0x2B,
    0xA7,
    0x2B,
    0xA8,
    0x2F,
    0xA9,
    0x2F,
    0xAA,
    0x2F,
    0xAB,
    0x2F,
    0xAC,
    0x32,
    0xAD,
    0x32,
    0xAE,
    0x32,
    0xAF,
    0x32,
    0xB0,
    0x35,
    0xB1,
    0x35,
    0xB2,
    0x35,
    0xB3,
    0x35,
    0xB4,
    0x38,
    0xB5,
    0x38,
    0xB6,
    0x38,
    0xB7,
    0x38,
    0xB8,
    0x3A,
    0xB9,
    0x3A,
    0xBA,
    0x3A,
    0xBB,
    0x3A,
    0xBC, -- Set Dark mode and 1st frame
    0x3C, -- set pulse width
    0xBD, -- Set Dark mode and 2nd frame
    0xBE, -- Set Dark mode and 3rd frame
    0xBF, -- Set Dark mode and 4th frame
-- end grayscale settings
    0x38,    -- 1-st
    0x74,    -- 2-nd
            -- The Instruction of EXT=0 Mode is available
    0xAF    -- Turns the display ON
delay = 10
    pinToOUT(SCL)
    pinToOUT(SDA)
    pinToOUT(RST)
    pinToOUT(CSB)
    print("CSB to 0: ")
    setLOW(CSB)
    print("CSB == ",gpio.getv(CSB),"\r\n")
    vmsleep(5);
    print("RST to 0: ")
    setLOW(RST)
    print("RST == ",gpio.getv(RST),"\r\n")
    vmsleep(100);
    print("RST to 1: ")
    setHIGH(RST)
    vmsleep(100);
    init_LCD();
--The end
