Actually, before I post my question, I download the spec of
1) 74AC374 from ST
It states that 74AC374B = DIP; 74AC374M = SOP
2) 74AC374 from Fairchild
It states that 74AC374SC = SOIC; 74AC374SJ = SOP
So, I'm confused, are they the same?
DIP is through-hole, SOP is SMD, SSOP is SMD but smaller than SOP. 8-DIP = 8-pin IC; 8-SOP = 8-pin SMD IC..etc.
However, SOIC? it means small package IC. I can call 8-SOP and 8-SSOP as a SOIC, am I right? pls kindly correct me if I'm wrong. But, why the spec stated that the package of 74AC374SC is SOIC?? :cry:
The SOIC and SOP should be the similar outline, but the dimension (lead pitch) is little different because of the package develop history, for SOIC is 1.27mm, for SOP is always below 0.65mm, see reference below:
