I strongly recommend to discharge the cap before installing it.![]()
Good point
Modern caps use much better electrolytes than the caps from 30-40 years ago. They don't need the higher voltages to get good plate charge formation and they almost never need "conditioning" any more. Both those concepts are pretty outdated.
30 - 40 years ago? Are you trying to age me?
I wasn't building amplifers in the 50's or 60's. I was running around in diapers. The relevance is much, much more recent.
Some manufactures still publish guidance as to minumum voltage.
3.1.2 Operating voltage Vop
The capacitors can be operated continuously at full rated voltage (including superimposed AC voltage) within the entire operating temperature range.
The permissible voltage range for continuous operation lies between the rated voltage and 0 V.
For short periods of time, the capacitors can also handle voltages up to -1.5 V (refer to chapter "General technical information, 3.1.6 Reverse voltage").
When the actual operating voltage is below the rated voltage, the operating leakage current is substantially lower:
The useful life can be prolonged by operating the capacitor at loads below the rating values (e.g. lower operating voltage, current or ambient temperature) and by appropriate cooling measures. In addition to the standard type series, EPCOS is able to offer types with useful life ratings specially matched to customer specifications.
The company was created in 1999 from Siemens Matsushita Components, which was a joint venture of Siemens AG and Matsushita in 1989. The stock opened on 15 October 1999 at the same time in Frankfurt and New York, with Siemens and Matsushita holding interests of 12.5% each. In 2006 Siemens sold its shares of Epcos. In October 2006 Matsushita also sold its holdings. TDK Corporation agreed to acquire a controlling stake in the company on 31 July 2008.[1]
It didn't contridict what I've been saying. You just didn't read far enough.
It obvoiusly does not contradict what I've been saying. I've said all along it's an optomazation.
Newer literature from the company shows what I'm saying. https://www.epcos.com/inf/20/30/db/alu_x/B41161.pdf
The recommendations are a result of newer literature, not lead type.
This I guess you should call up capacitor manufactures and educate them about their products. Some still think their caps work better within a voltage range.
It's not only me, as I've illustrated over and over.
