Credit card size, A 900MHz quad-core ARM Cortex-A7 CPU, 1GB RAM, 4 USB ports, 40 GPIO pins, Full HDMI port, Ethernet port, Combined 3.5mm audio jack and composite video, Camera interface (CSI), Display interface (DSI), Micro SD card slot, VideoCore IV 3D graphics core (Win-10, Android or Linux)
I have the dual core in the other room (mounted on a mini hard drive). It surfs the internet just find. I am looking at the 8x core version.
Version 2 = $41.95 usdI guess around 50 bucks?
Look at the video engine in this thing. It does real time video processing at 1040 res.some image processing
I want to build a sonar, using a Rasberry computer. Using a servo motor and sonic range finder. It might take a minute to scan.radar
I'm with granddad. I have been in electronics for over 60 years, and I remember when the transistor first became available, and built my first digital clock with RTL ic's(way obsolete). My current project that gets put aside quite often is a US Flag with 400 LED's.
Almost a no brainer for my own interests with a truly unlijmited parts supply,
i'd build a SUPER COMPUTER.
I would also create the strongest chess program on earth for it, better than Deep Blue.
I've already considered some alternatives in hardware even with limited hardware. Already have a base chess program also that might not be the best one on earth, but is still hard to beat for the average player. Installed on a super computer however, it would beat all but the best, and with a little tweeking it would be extremely hard to beat.
Before that though i'd install a lot of programs for electronic design.
I would complete my matter transfer device and beam former wife #1 into the center of a brick wall.What would you build first?
I think if you build a rotating sonar you've probably conquered half or more of your problems for a radar. I have an ultrasonic range module for my micro-controller board. There are plans out there for a range finder, so that's already half the battle. You only need to build a different kind of detector at that point. Personally I think the writing software to display your contacts will probably be at least as difficult as the electronics.I want to build a sonar, using a Rasberry computer. Using a servo motor and sonic range finder. It might take a minute to scan.
Radar is a step too far for me.
anorak, no, coffee , no, woolly hat only down the allotment...Eric
PS: I don't wear an anorak, drink coffee from a flask or wear a woolly hat.![]()
Scratching head , the octave keys ( notes ) are usually assigned to 1-2-3-n voices on block ( channels ) also notes have sustain, ie channel voice keeps playing after note key is up ... Did i not get your drift.I've figured out how to automatically assign a key to an available synthesizer channel,
I had not thought of using strips, I'll look into it, thanks for the idea.Strips are quite common. Why not?
Yes, it would still have attack/sustain/decay. The idea is that if you have a 72 key keyboard, you can't hit all 72 keys at once. You only have 10 fingers. So, there's no need to have more than 10 channels of tone generation. Of course, if you have the notes set for a long decay time, and play a lot of notes really fast, then you could run out of channels before the earliest note fully decays. The oldest note just gets cut off. This is certainly a limitation to the technique, but still an improvement over the old monophonic Moog synthesizer.Scratching head , the octave keys ( notes ) are usually assigned to 1-2-3-n voices on block ( channels ) also notes have sustain, ie channel voice keeps playing after note key is up ... Did i not get your drift.
