I'm Stuck on this thermostat.. Please help.
Luke,
My apologies for the delay ! It appears that the circuit is triggered 'ON'
ALL the time.
1. Is the Light(LOAD) is OFF when you disconnect pin 6 to the gate of the triac ?
Let's insure that pin 4 and pin are connected somewhere, And NOT left floating.
2. Tie pin 2 to Vcc with a 100K resistor for R3.
3. Tie pin 4 to Vcc with a 47K resistor(R1).
With these values the circuit should trigger at ~ -2.9V or >.
Try again ! Please attach the present form of the circuit with ALL part values.
Fred
SUCCESS!!!! (least I think so)
Hi Fred
Sorry for the late reply.
Well I think we have broken the back of this problem. When I reversed the ac wires earlier(as you advised) I did not change the wires for the triac. With this setup the light stayed on all the time.
I changed the wires to the triac and now it appears to work. The lamp flickers
when the sense voltage is around -2.75volts and it goes off at around -3.00volts and when it is really low eg: -1.0volt it is on constantly(just the occasional flicker).
I believe that I now just need to play around with the resistor values in the divider and It will be working.
I would like to add a fuse to this circuit( for safety), where should this be added?
THANK YOU FOR ALL YOUR HELP!!!!!
You have been so helpful.
I hope I am not jumping the gun with this circuit, I dont think I am.
Cheers
Luke
Luke,
Great call on observing to reverse the leads on the triac. (sorry that I missed that one) !
Now you know alot more about electronics. ( NTC thermisters, capacitors,
triacs, Leds, and breadboarding prototypes)
This is quite an accomplishment AND for a good cause...Python Eggs !
What made you think to change the triac leads ?
I would place the fuse (3AT @220VAC), in series with the 'HOT' lead that feeds the common connection Cathode of the 1N4004 and 300W bulb.
Are you O.K. with calculating the voltage divider 100K(NTC) and Rdef ?
The NTC @ x degrees C = x K ohm( say 100K @ 25C), Then
Rdef(4.7K)/ R ntc + 4.7K ~ 2.75V....the set point.
Take care of those Python eggs !
Cheers,
Fred
Hi Fred
Thanks for the compliments.
To be honest it was a bit of a guess. I just thought it had too be something with the triac. Everything else seemed ok. And with changing the supply wires I thought I might need to change where the gate fed from.
I should be ok with the calculations.
Thank you again for all your help and support. My pythons will benefit from your help.
Honestly I think forums such as this and the people on them such as yourself are what makes the internet so great.
I definately feel motivated to learn more about electronics now.
Thanks again
Luke
:D
Luke,
I am glad to hear that you are motivated with electronics !
Yes, I agree about this forum. I learned something too !
Take care,
Fred
