Exercise for the student: Down load and study both data sheets. What is the difference?Thanks! I notice you are using a TIP32c not a TIP30c, are they interchangeable? i only have tip30c handy.
Cheers!
Steve
Cheers!
Steve
My reading of the two data sheets is that they are interchangeable for this application.
TIP30
TIP32
Are you sure you wired it up right?
View attachment 90279 View attachment 90280
42 watts in a transistor...........probably will burn out.
P=U×I = 14.2× current of the panelIf this is connected directly to a 7ah 12v what kind of wattage will be dissipated? I mean if the solar panel has charged the battry to14.2.
Do all panels have the diode inbuilt ?I left out the diode because it is not needed.
If not, then the battery drains trough the panel, when the panel is in the shadow.
Not the current of the battry? 7ah?P=U×I = 14.2× current of the panel
The current which the panel provides at 14.2VNot the current of the battry? 7ah?
Steve
