Hello everyone! Story (skip below if you don't care): I'm trying to fix my rear tail light on my motorcycle. The running light wire became corroded or disconnected somehow. What I would like to do is reconnect it to another wire with the correct voltage on the bike. I tried virtually every wire already and when the bike is running they are all around 12volts, rather than the 9volts ish that the tail seems to like to run correctly (12 volts lights it up like you are hitting the brake constantly)...
So my question I guess is what kind of resistor can I use in order to bring voltage down from 12 volts ~ish to 9 volts ~ish? I found ones with a 5%, 10%, and 20% tolerance but is there something out there with a 75% tolerance perhaps? Not sure what to do. Thanks in advance!!
