Infrared Audio Link
ruthvikmagal
I am attempting to do an IR audio link and I'm frustrated as after 3 attempts, I couldn't get the following circuit to work - Simple IR audio link.
So, I'm planning to try a new circuit - **broken link removed**
Can anyone tell me if the circuit is fine?
Thanks in advance
Any analog modulated IR system is going to be unreliable. If you want to do it look for a system that creates a digital pulse stream for on-off keying of the IR path. It is more complicated but you get what you pay for.
There are probably some IC that can do the whole thing. If you want to be more into nuts and bolts look up a Sigma-Delta modulator. For receiver frontend I suggest you use an off the shelf module that gives you digital pulses out, like used in TV sets, since the biasing setup on an IR pin photo diode is a bit involved.
If you look at the circuit, you are using NPN transistors, usually when i see a circuit like this i'd expect the speaker in the receiver to go between Vcc and Collectors,, ,not ground and emitter.
