NJ Roadmap
Ok so I'm testing the system step by step and heres what I've come across:
1.Master is sending a 01010101 in a loop out of a a generic digital I/O pin
2.AM TX module modulates amplitude between about 10V RMS and 6V RMS
3.AM RX module on Slave gives pulsed output, but since I only have a multimeter I can't really say whether the high pulse out of the RX module's digital out pin is over 2V for TTL high.
This is because I need a fairly long high pulse for the multimeter to settle and show me the right voltage. I understand that if I do try to send too long a high pulse from the TX module, the output from the RX will fall low after a period of a few 100us.
I've tried varying the distance between the two modules for the same duration high pulse, and either:
1.the voltage for digital output high from the RX module decreases with increase in distance, or
2.the pulse duration gets shorter with distance - I can't say which again because of not having a scope and only a multimeter.
Ok so I'll get access to a scope in the morning but I'd rather have an answer now than wait till tomorrow. Basically what I want to know is whether these AM RX module's voltage for digital output high varies with distance from the TX module, or is it the pulse duration which shortens? If it is the latter I guess I'm going to have to go with Manchester coding after all...if it's the first, this is a much bigger problem!
Another couple of questions (if you don't mind ):
-the TX module can take up to 14V in and is currently powered via a 5V regulator, I'm thinking of giving it about 12.6V out of the 12V regulated mains PSU which powers the whole board. Would I need another 12V regulator just for the TX module or can I do without it?
-I got a couple of 1/4 wave 433MHz flexible whip antennas (monopole), one connected to the antenna pin on the TX module and another to the antenna pin on the RX module. I'm guessing that's good enough for about 5 metres through one wall?
Thanks in advance!
Thanks in advance!
