Inverter FIF1742-60A test
2PAC Mafia
Hello,
I have a monitor and I´ve found the problem is the back light. It uses inverter FIF1742-60A and I´ve seen for 1 or 2 seconds I have high voltage output. Now I´m wondering if the board itself have some problem due a feedback or similar or may be some of the lamp is not working and this is the reason why the inverter stops.
If I measure at lamp connectors I don´t get any resistance between terminals... on 4 connectors...
The brain of the board is MP1048.
How to test them? I have seen useful CCFL testers in Internet.
  • Inverter FIF1742-60A de monitor Visio 19 EUR.pdf
  • MP1048.pdf
I tested with another inverter and it´s the same situation so I´m pretty sure the problem is at CCFL... Now I see that measure no resistence is normal at CCFL :)
I agree.
CCFL's are open till you reach the strike voltage, which can be 100's of volts.
Unless its a very expensive monitor is probably dead, but keep the boards if its a comon one.
