Hi all,
I have a older DC to AC inverter, specifically a Collins T426-1 that outputs 115Vac @ 400Hz from a 28Vdc input. My problem is that as soon as I hook up a load to it the output frequency jumps to 3.4Khz! I tried a second Inverter and got the same result. Here is the exact set-up, 28Vdc to Inverter, 115Vac 400Hz out to a step down xfmr which is 28Vac 400Hz out to an aircraft instrument. The instrument only has a 1amp draw and the Inverter is rated at 650Va. Any idea what could cause the frequency to be so high and what should I check.
Rob
Rob
