Mr Al. Thanks for your offer.
For now, I solved the immediate problem. I now just need to curt and drill and mount the switch and see if it holds up mechanically A 9Vbattery and a LED would work perfect for a quick design.
When and, if I get the Ethernet Patch panel done, I could pass that indicator upstairs to the bedrroom which is not a bad idea either. The panel is mounted, but no connections yet. Thanks for that idea. I could even do that in addition. The LED in the BR is the lowest cost.
I bought the DIN rail parts for (power supply, a few isolated contacts and a contactor that would operate off of 12 V). I would also need to cut a lowvolateg cutout for the wiring. Turning on a 120 V lamp (standard wall switch) would be PERFECT, because the lamp needs to be on to peer into the freezer.
A UPB system is inn the works too for one light.
I do have lots of sensors that need monitoring, or at least lots I could come up with. I have a wireless water alarm, but there is again no external outputs. One water alarm sits on a towel and the other has battery monitoring and is wireless and sits in the "french drain" with the receiver in the bedroom. But it doesn't help if our not home.
The refrigerator has the old fashioned locking handle, but also has a curved door so mounting will be more difficult. The door being open is more likely than it being off. There is no defrost, but I have the fridge turning off one hour a day.
I just would love to have a decent SMS alarm system that doesn't cost an arm and a leg.
Oh so you have everything the way you want it now? That's good then. I thought maybe you wanted to do it over or something to get more accurate monitoring, but if it works, that's good and your done
