Well I got this in an PM so I guess the zombie is still kicking.
Sent to me from Deadsheriff who has zero posts at the moment. Anyone want to take a guess at his affiliation?
__________________________
HFAC is used by the space-station, aircraft, rockets, satellites and a lot more critical device applications. It is used because apart from NOT being a frequency BEST suited to effect myocardial damage such as 50Hz, it runs just so much more efficiently to do just so much more. This includes reducing the size of compressor motors in fridges/aircon, makes smaller power supplies from battery chargers thru TVs and microwaves in your home to the redundancy you might need for an electric car charger/de-ioniser. It is also more suitable for inverters off solar arrays - because at high frequencies you can use pure sinewave resonant generation - too much chunky iron at 50Hz so it is normally piecewise synthesis noisy and inefficient.
Osram picked Isotera up to set off trying to market it ...but if the standards people make HFAC the domestic power distribution standard - wow for those poor silly Isotera shareholders. Its not just about connecting up dumb lighting - after all Isotera STILL need to regulate down/up for their LED arrays....others such as below DONT...they use resonant regulation - as long as something is regulated the "head" will only supply just so much power before it ISNT resonating. They regulate by POWER limitation, after all the Vfrwd voltage is "clamped" so they get "current" regulation and a lot more such as 50% of the LEDs fail and they keep running - parallel columns notwithstanding !
SO ....check this out - you are all aware we are running out of EM bandwidth ...right ?
I found this little gem on Utube by accident ....I followed the accidentally left link before it was made "private" ...it is a bonafide system being employed by one of the biggest buildings in Sydney...truly new stuff. For example if we double EM data throughput we have to square the cell tower density - scary costs here !! Whereas there is 10,000 times more bandwidth in the optical spectrum than ALL the EM bandwidth we have used to date ...yikes..since Marconi !!.
I am here because I googled for Isotera ! And got worried by all the vitriol - poor ol Flyback ! Here is a helping hand mate ....
It will soon be publicized I am told....BUT it has absolutely ZERO switching semicon in its deployment.....so if the 1KW redundant sync'd HFAC supplies trundle on, reporting to the IoT space if one goes down to stimulate remedial action by you techies (or the lady at the front desk can do a hot plugin), there isn't many things that can go wrong .....AND the Internet services industry will get turned upside down methinks - so much data bandwidth at such a low M2M level ...wherefore the average ISP business ???
So don't cry for Osram - or those Isotera shareholders ....they be looking pretty to my mind...unfortunately I am NOT one, only found out about them a month or so back.
and just when I thought it was safe to put my axe and zombie smacking shovel away.
